Hello everybody! I discovered this website when searching for some information on the project I had in mind for quite some time now: Building my own pure Class A amplifier.
The problem with this is that actually, I'm quite illiterate in electronics. I mean, I know how to hold a soldering iron and I can tell a transistor from a diode , all the basic stuff so to speak, but I have no idea about the whereabouts of damping factors, harmonic distortions generating from the circuit itself and the different types of resistors used for an example, the different design philosophies of amplifiers, and other more complex aspects of electronic devices. Does anybody have some good recommendations for freely available material (pdfs for an example) that I could read through to understand more about things like that?
But back to my amp project. First of all, I would like to keep the money involved down to a minimum; I may have some good possibilities to get expensive/big parts like used power supplies and huge capacitors for free or very cheap, and I also have access to machining for building a good chassis.
The vague concept I have in mind at the moment would involve completely separated channels using two separate power supplies, a power output of around 20-50W, a very simple preamp section (no multiple inputs, resistor bridges for volume control) and in general the most minimalistic yet efficient material possible. Volume and weight of the whole thing (and for the major part visual appearance) don't matter to me a lot - in fact I could even incorporate car batteries into the amp for stabilizing the DC, if that would make a lot of sense.
My equipment is a bit limited as well: I would be using two soldering irons (both non-controlled, one 15W, the other 30W), a €20 digital multimeter. Unfortunately I don't have access to an oscilloscope.
So do you guys think it would be possible for a person like me, who has only superficial experience with electronics but a lot of time at my hands, to build anything worth the effort using this concept for under €100?
And then of course, as you can probably guess that I can't etch my own circuit boards, left alone design an own circuit, what existing amp model would you suggest me to build?
Hope I didn't ask too many questions that could have been answered by using the wiki or the forum search function - I just couldn't find those very basic "what you need and what you have to expect" answers in there.
So thanks in advance for your replies,
Chris
Chris
Chris,
Welcome here.
No need to tell that this forum is an excellent resource of knowledge.
Have a look at Nelson’s articles at www.passdiy.com as well.
As for the price tag, class A is never cheap (big transformers, capacitors and heat sinks) but I’ve seen many projects being build from recycled material.
20-50W? The AlephX comes to mind but I would advice a more simple amplifier as a first project. Something Zen as a starter will keep you away from frustrating debugs and is excellent learning material.
/Hugo
Welcome here.
/Hugo
Read
Passdiy articles and projects
Passlabs articles
Then, you could soon find yourself as a semi-pro . . .
Passlabs articles
Hello Hugo,
thanks for your reply!
I'm right now looking through the passdiy site, and I think there's indeed a lot of valuable information on there (did only know the passlabs site yet).
I think I have to agree that 20-50W for a class A amp will be quite an overenthusiastic first DIY project - let's correct that down by the factor 10 - 2-5W, perhaps 10W will probably be adequate enough, as I only have a 16m² room to listen to the music actually.
Another correction appealed to me when almost sleeping last night - why should I go the route of using analog chinch inputs and resistors for varying the volume, when actually both devices I intend to use with this amp (Yamaha CDX 593 and an M-Audio Delta Audiophile 2496 soundcard) have digital outputs and incorporate ways to adjust their volume digitally - if I knew it wouldn't be completely over my head and far out of my intended budget region (could somebody please tell me that it isn't! ), I would just build the amp with a D/A converting pre-amp and no volume control at all.
Chris
Chris
Hi Chris,
Have you considered a mini-aleph?
http://www.diyaudio.com/forums/showthread.php?s=&threadid=2001&highlight=minia
It's small and cute and you can get PCBs from BrianGT:
http://chipamp.com/orders.shtml
This is essentially a smaller version of the Aleph3/30. As NetList
has mentioned, class A means big hardware (caps, transformers
and heatsinks). Since you seem to be covered in this
area, you're probably in better shape to build class A amps than
a lot of us.
As an FYI, I did not have an oscilloscope when I built my Aleph 30.
Good luck...and welcome to the forum.
Dennis
a lot of us.
Dennis
Well, especially in terms of heatsinks/cooling I think I may have an advantage, since I'm more of a mechanical DIYer most of the time, so I have lots of scrap metal in my workshop, and the tools to give it the necessary surface area. Perhaps I might even go for liquid cooling using a few external pumps and car radiators or similarly capable equipment, since it's very much possible to get the heatsinks on the outside of the case, as opposed to computers; I could imagine such a configuration to be easily capable of disposing a few KWs of excess heat without a lot of hassle. Transformators probably won't be too much of a problem either; the biggest factor will be capacitors.
I don't know if it would make any sense to run car batteries across the power supply for cleaning the DC - has anybody taken such an option into regard yet? It would definitely take up a lot of space, yes, but it would also offer more capacity for the money than anything else I could think of - I just don't know if the batteries would be up to the job. Of course, for the amp itself I would use the same new and expensive capacitors from electronics shops as everybody else - I heard it wouldn't be a good idea to reuse amps from old equipment, can anybody confirm this (or actually, I'd prefer if somebody told me I could use them as much as I like without any problems for the quality of the amp)?
Well, however, I have to say thank you guys for those links, I will try to get as much information as possible before actually starting my project.
Chris
Chris
Most use NOS caps.
You can check if Wim still has some 33.000uF Rifa PEH169 left.
www.diyaudio.com/forums/showthread.php?postid=655237#post655237
choky said:
where?
Still in my personal computer, looking for a reliable ISP.
The first draft will be released in two weeks.
I risk being unpopular at the Pass forum and advise you build a Gain Clone first. There is little to go wrong (a single chip with a few passive components, with built-in protections), and you do not risk getting oscillations from a discrete circuit. Also low budget, as heatsink & power supply costs are not high. Just look at Peter Daniel's website (e.g. for the integrated amp).
And then if you get hooked, just like all of us, you might consider something discrete like one of the Zen versions, or the GC Symmetry here at the Pass Forum. Then you would want to invest in an oscilloscope from ebay, which I consider minimum equipment in addition to multimeter.
I assume that you have not been too humble to admit you have a degree in mechatronics or physics, etc.
Patrick
Patrick
Well, those pieces of advice are probably coming a bit too late for me - I just ordered the PCBs for an aleph series amp from chipamp.com. Another problem I would be facing when going for anything else is that after reading through a *lot* of websites, pdfs and other information sources in the last days, I think I got convinced of the whole concept of a single ended Class A amp with a constant current source - for what I know about the whole matter, it matches my ideals of what I look for in any given device very well: keeping it as (seemingly) simple as possible, while doing what it's actually intended for a whole lot better than anything that goes for compromises. I'm the sort of person who prefers non-stainless-steel blades to their less maintainance-intensive cousins.
Now that I think I found a very appealing concept, it would be very hard for me to get out of the whole idea and look for something else, just because it might be easier to build or (seemingly) less expensive - as they say, cheap equipment costs you the most money, as you eventually need to buy the good stuff afterwards, and I would certainly be eaten up by doubts if I built another amp, even if it turned out rather nicely - how much better would an Aleph or a Zen amp sound in comparison?
To answer the other question, no I don't have any degree in anything (yet), I merely studied 2 semesters of mechanical engineering and would consider myself quite proficient on the mechanical/craftsmanship side of things, as well as on cooling and general thermodynamics. I also built my own speakers from a kit (Mivoc SB-180-II), and take all attempts to repair electrical devices around here whenever they appear, which however go wrong for like 75% of the time so far. So I'd consider myself handy with the basic ideas of soldering/screwing things together, but not with stuff like getting rid of resonances/oscillations you mentioned I could run into (I hope they come from the actual PCB layout, or appear only with bad soldering spots).
Analysing electrical problems that go beyond a soldering spot or an exploded cap is something I still have to learn, so to speak.
I might definitely go for an oscilloscope, as I could use it on a lot of things I do - it's just that for my student's budget those €100 or so are a rather big investment. Well, however, I'll keep you guys updated, if there is anything interesting to update you on.
Chris
P.S.: I feel very, very honored to receive advice from Mr. Pass himself (even though I won't follow it, for the above mentioned reasons )!
Chris
Apropos of nothing, I recall a story from Larry Klein, who edited
Stereo Review for many years. Preciously he worked for
Heathkit, and one day a customer sent in an amplifier for work
and when they opened it up they found that instead of soldered
wiring, all the component leads were bolted to each other by
jeweler's screws and nuts.
Nelson Pass said:........................ all the component leads were bolted to each other by
Passion ,what else?
Perhaps I might consider that as an alternative, if I feel the need for a little bit of extravaganza and crazyness (apart from actually building myself an amplifier that gives away several hundreds of watt in heat just for idling, although I have a perfectly functional consumer amp in a pretty, non-offensive color sitting on my desk - one might easily forget about it when browsing through this forum, but where I'm from, that does actually still gain you a seat in those categories).
Chris
Chris
Nelson Pass said:a customer sent in an amplifier
Must have been a Swiss owner.
- Total newbie questions...
