So, I have been building an A30 for about a year. A little bit here, and a little bit there. I also have an X-Bosoz built, but not in a case. I decided a few weeks ago to get these things going to power my Klipsche's. About time I think.
So, I made up a frame out of some 3/8" aluminum bar stock (two 12x12.75 rectangles) and will bolt the heatsinks to it. Front and rear panels will be .090 aluminum, but the front piece will sit inside a 1.25" think piece of walnut. Top will be again, aluminum sheet with walnut on top of it. Large rectangular vent holes will be covered inside with heavy brass screen. Bottom will be brass screen. The circuit boards will ride on cross members running across the frame, and the various trafos (2 - 400VA 16Vx2 for A30) will ride on vertical members behind the front panel. Anyway, I was test fitting the A30 bits, looked over at the x-bosoz, and bing. No seperate case for the x-bosoz. Also included will be a balanced darwin source selector and a joshua tree balanced attenuator. I won't need the dual outs of the darwin, so just two knobs on the walnut front, volume and source. Will have 6 sets of XLR inputs. Will also use MaxHawk's soft power switch (red led). Should be done in a few weeks!! Finally some pics....
Twisted Pear Audio |
#2 |
Hi Brian,
Very cool indeed! I'm surprised tha more DIYer's have not build an integrated unit. Besure to post the final assembly pictures. I like the big copper spreaders. I imagine it took a lot of heatsink compound to cover that surface area. -David |
#3 |
I love solid metal cases! keep the pics coming
#4 |
I shoudl point out that the only non-wood working tool I have used so far is a hacksaw to rough cut the copper, as it doesn;t play too well with the tablesaw.
The aluminum frame was cut on a chopsaw and the panels will be cut on my tablesaw. I think if people knew how easy it was, more would be making metal cases. EDIT: well, i did use a milling machine to face mill the copper, but didn;t really have to
#5 |
...also, forgot to mention (beer) that I am using Peter Daniel's A30 boards and BrianGT's PowerSupply board. Might add a second PS, even though the one I have uses 6 - 22,000uF caps
#6 |
ugly!
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#7 |
Looks good Brian, keep it going while the spirit is there
Great idea going integrated, never crossed my mind. Always had my hands full keeping the poweramp cool enough Steen |
#8 | |
#9 | |
you are more than welcome!
#10 |
Ahhhh...... reminds me of a dream i had last night of a X-bosoz and Sussy!
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| Integrated? | rootbeer | Class D | 4 | 23rd December 2008 08:35 PM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| What can $200-500 get you for integrated amp? | chuck55 | Solid State | 5 | 12th February 2006 07:00 AM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Page generated in 0.10425 seconds (78.54% PHP - 21.46% MySQL) with 10 queries |
