In an italian revew of this amplifier the reviewer said "I found on it a little defect common on many american hi-power amplfier, the 99% of it, when the volume increase very much the size of the instruments become bigger" Any one would like to explain to me this phenomenon?
Thank You all! |
#2 | |
phenomenon known as "short circuit between reviewer's ears"
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 | |
The one and only
#4 |
Google "Fletcher-Munson"
The instruments are not getting bigger; your ears are getting smaller. |
#5 |
actualy room becomes bigger..
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!.. |
#6 |
The fatter the speaker cables the larger and louder the sound.
Bigger instruments are aloud to pass through to the speakers at louder levels. |
#7 |
All you guys are too quick to condem.
Take two identical amps except one has little damping factor, the one with good damping factor will sound better driven harder than the one with bad damping factor. The one with bad damping factor will sound better at lower volume though because it fleshes out the bass at that low volume, where as the one with good damping factor may sound lean an enemic at low level. Think a little before condeming. Cheers George |
#8 |
The one and only
An amplifier whose output impedance various much with level
has a real issue - crossover distortion typically, and of course an amp with crossover distortion will sound better at higher volume. This does not describe an X250.5 which idles at 250 watts. |
#9 |
Maybe you would be interested in my new line of Fletcher-Munson compensators? One of these in series with speakers will not only decrease the damping factor but reduce those nasty Watts as well.
Seriouosly George, you do raise an interesting point as to how the reviewer misinterpreted his ears... |
#10 | |
Cheers George |
| Pass X250+ Wadia | martev | Pass Labs | 4 | 6th August 2009 08:44 AM |
| Lower the gain on a Pass X250.5? | aljordan | Pass Labs | 10 | 8th January 2009 08:26 PM |
| Pass X250.5 right channel hum problem | georgehifi | Pass Labs | 1 | 3rd July 2006 07:06 PM |
| Pass X250 concept ? | ANALOG GUY | Pass Labs | 32 | 17th February 2006 04:08 PM |
| Pass X250.5 question for Nelson | georgehifi | Pass Labs | 4 | 15th March 2005 07:37 PM |
| Page generated in 0.09673 seconds (84.32% PHP - 15.68% MySQL) with 11 queries |
