hello, I tried to search in forum but didnt find- why on all versions few resitors values are always diferent. I will be using 16 irf 244 Fets per channle with 22V rails and 11A bias. what value I should use?
thanks in advance..
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!.. |
#2 |
Hi elviukai,
this spreadsheet will help you I think from memory Version 3b calculates power incorrect, use Version 3A. You really need to use duncans psu simulator to get some idea what your final rails will be under load, especially with 11 amps bias. http://www.diyaudio.com/forums/showt...481#post275481 |
#3 |
Hi Luke thanks for excel calculations. I already have 2 versions of them. unfortunately they do not tell whay they using one or other value of resistors wihich I marketed
I am not electronic engineer and woul be nice getting nice start point. I noticed that in higher power versions it lowers from 4.7kohm to 3.3kohm. what theese resistors doing?
#4 |
these 10k resistors set the gain of the amp. You can leave them as they are (togheter with the 100k resistors). Some people changed the gain by changing the 100k to 150k (x15=23.5dB instead of x10=20dB) William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#5 |
hi wufwaf. once somebody told me to rise input sensitivity to drive via passive praemp.( I using passive preamp and wanted better input sensitivity but not lowering input impedanse) increase 100kohm value. I increased to 130kohm. get arround 15V output at speakers and quickly changed my mind
ant theese 4.7-3.3ohm near input 9610 mosfets? why thery are varying. its pain when I do not know electronic basic knowlwdges
#6 |
just keep the 4k7 if possible. Lowering them betters the absolute-dc-offset behaviour but also the sound. william
#7 |
thanks wuffwaff, and regarding theese 100 -33kohm resistors? thay also varying. and output resitors 4x 0.47ohm ,sometimes I noticed that in higher power verion people ad some pair = 6x 0.47ohm what does it means and decreasing output resitors do I need change output to ground resistors(33ohm) ?
#8 |
Sorry elviukai,
I misunderstood your post. regards Arthur |
#9 |
Elviukai,
itīs the same story for the the output to ground resistors. Start with 100 Ohms and lower if absolute dc offset behaviour is not ok. The source resistor value depends on the bias per fet you are using. Aim for 0,5-0,6V at the chosen bias. The output resistors can vary too, lower values give less power dissipation and less voltage to steer the active current source. Tollerances will be bigger if the value getīs lower but normally you will set your ac-current gain with a pot first so thatīs not such a problem. William
#10 |
start with 100ohm? all design I have ever seen use 33-22ohm(pfor example 3x100ohm)output to ground
tomorow is the big day -I will try to start up my aleph x monoblocks. 22v rails, 12.5A per channel, 16x irfp244, 1x 2Kw toroid per channel. I hope I will not blown anything as usualy
| Bleeder resistors, What values? | bowdown | Solid State | 15 | 28th March 2007 03:21 PM |
| Opamp gain setting resistors values | deduikertjes | Solid State | 7 | 20th June 2006 06:59 AM |
| Calculating a stepped attenuator resistors values... | youyoung21147 | Parts | 3 | 13th June 2005 07:07 AM |
| resistors values | jaudio | Chip Amps | 0 | 19th March 2005 03:50 AM |
| Page generated in 0.09748 seconds (82.15% PHP - 17.85% MySQL) with 11 queries |
