Old 31st May 2006, 10:01 PM   #21
bravi is offline bravi  New Zealand
Default PDF of PCB
Russ,
WHen do you plan to offer PCB of this circuit for sale
Old 31st May 2006, 10:44 PM   #22
Russ White's Avatar
Send a message via Yahoo to Russ White
Default Re: PDF of PCB
Originally posted by bravi
Russ,
When do you plan to offer PCB of this circuit for sale
For those of you who want them we can get some soon, probably in the next month. Just drop me an email or something so I can get an idea how many to order.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 1st June 2006, 10:23 AM   #23
st2_998 is offline st2_998  Italy
st2_998's Avatar
Ross, in your opinion does it make sense to use this circuit for a buffer with both input and output unbalanced? (I yet don't understand if it makes sense for X-BOSOZ too...)
Will it be stable at unity gain?
In order to use it with OPA1632 something should be added perhaps ("control for common mode offset" Mr. Pass said)?
Luca
Old 1st June 2006, 11:20 AM   #24
Russ White's Avatar
It would work SE-IN/SE-OUT but it might be a waste since you would not get much benefit from the chip. If you want an SE buffer I would look at something like the "Kookoo" which I design specifically as an SE linestage/buffer for the Joshua Tree (it is designed to stack).
I believe OPA1632 should work just fine without any circuit modifications. You just may need to play with the resistor values a little. I will have to dig into the datasheet and see if I can find any clear changes to make.
Cheers!
Russ
Old 1st June 2006, 03:42 PM   #25
steenoe is offline steenoe  Denmark
steenoe's Avatar
Russ, I have to repeat the question: Do you ever sleep?
I am wondering if this circuit sounds as good as a purebreed Twisted BosoZ?? If this was not in the middle of the fishing season, I would build one right away Very good work, and very kind of you to share the pdf's If you continue like this, you might start the whole tube/solid-state discussion all over again Just with X'ed chips and mosfets as subjects
Steen
Old 1st June 2006, 06:29 PM   #26
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Russ, any chance you could share the eagle .lbr for the THS4131?
/U.
Old 2nd June 2006, 03:49 PM   #27
st2_998's Avatar
Default Kookoo
Sorry Russ, I guess I'm OT here, but I couldn't find any schematics of Kookoo (if any had been posted), and couldn't find anything on Twisted Pear either. Can you help me?
NB: "Stacking" on JT sounds very interesting to me.
Luca
Old 2nd June 2006, 04:09 PM   #28
Russ White's Avatar
Hi Guys,
As to the library I will share it here shortly.
Here is the link to the KooKoo:
http://www.diyaudio.com/forums/showt...534#post901534
It is also designed to stack with the JT.
Old 2nd June 2006, 09:10 PM   #29
sorry had nothing to do (waiting for a taxi )
Russ, damn.. you know the word vacation?
Old 16th June 2006, 11:37 AM   #30
Blimp is offline Blimp  Netherlands
Blimp's Avatar
Hey Russ,
Excellent, I was looking like this for a while to feed mine UcD's.
Just curious, does the Joshua Tree comes at the input or the output of the Sibling?
Do you have an estimate for the costs?
Gr, Bastiaan
OPA627 Buffer Based Preamp ianpengelly Solid State 30 27th January 2010 12:04 PM
Elektor-based 35 W self-oscillating boost converter Bootstrapper Elektor 2 26th October 2008 01:41 PM
Battery Based High-End DA Converter. yangsmm Vendor's Bazaar 14 21st August 2008 12:24 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Attenuator based on I/V converter jcarr Solid State 8 22nd December 2002 12:51 AM
Page generated in 0.43824 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
