Twisted Sibling - THS4131 based preamp/buffer/SE-BAL converter - Page 2 - diyAudio
Old 22nd May 2006, 10:19 PM   #11
Russ White's Avatar
Send a message via Yahoo to Russ White
And the very plain front.
Less pulp more juice Twisted Pear Audio.
Old 22nd May 2006, 10:29 PM   #12
00940 is offline 00940  Belgium
the opa1632 is apparently the same chip and cost way cheaper than the ths4131.
Ben.
Old 23rd May 2006, 01:10 AM   #13
Russ White's Avatar
Similar, yes very much so, the same no.
Old 23rd May 2006, 01:46 AM   #14
Russ White's Avatar
Ben,
The beautiful thing is that the OPA1632 and a few other ICs will work just fine in this circuit.
Cheers!
Russ
Old 23rd May 2006, 07:46 AM   #15
The question was raised here : OPA1632 and THS4131
You got more info from other sources ? The specs are so amazingly similar...
Ben.
Old 23rd May 2006, 11:39 AM   #16
Russ White's Avatar
I will call TI today to find out, but I can see some differences in the data sheet (though not many and not by much) but the big thing is that the THS413x data sheet specifically states this:
The THS413x is one in a family of fully-differential input/differential output devices fabricated using Texas Instruments' state-of-the-art BiComI complementary bipolar process.
Where as the OPA1632 does not.
Does that mean anything? Well who knows. But in the end both chips are cheap and you can use either one. So am not sure how it makes any difference.
I will call TI today and ask, just to satisfy my curiosity.
:EDIT: missed most of the quote.
Cheers!
Russ
Old 23rd May 2006, 07:02 PM   #17
The one and only
Nelson Pass's Avatar
One obvious difference is that the 4131 and its brothers have
an internal control for common mode offset, and the 1632 is
external.
Old 30th May 2006, 09:59 PM   #18
I would be glad if you post the pcb pdf.
Thank you
Giorgio
Old 31st May 2006, 06:09 PM   #19
Russ White's Avatar
Thank you
Giorgio
Your wish is granted.
The copper PDF is not mirrored (for toner transfer).
The silk PDF is mirrored (also for toner transfer).
Enjoy!
PDFs
Cheers!
Russ
Old 31st May 2006, 07:56 PM   #20
great!!!!
Thanks a lot.
Giorgio
OPA627 Buffer Based Preamp ianpengelly Solid State 30 27th January 2010 12:04 PM
Elektor-based 35 W self-oscillating boost converter Bootstrapper Elektor 2 26th October 2008 01:41 PM
Battery Based High-End DA Converter. yangsmm Vendor's Bazaar 14 21st August 2008 12:24 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Attenuator based on I/V converter jcarr Solid State 8 22nd December 2002 12:51 AM
Copyright ©1999-2017 diyAudio
