BOSOZ L/R imbalance problem - Page 2 - diyAudio
Old 21st May 2006, 12:41 AM   #11
poobah is offline poobah  United States
poobah's Avatar
Don't destroy the FET if you can manage it... just off the cuff guess.
The giveaway is that it works (well sorta) with power off...
Old 21st May 2006, 12:46 AM   #12
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Really ? You don't think it could be because there is still power left in the psu ?
Old 21st May 2006, 02:23 AM   #13
Account Disabled
Default Re: BOSOZ L/R imbalance problem
Originally posted by dw8083
Any ideas what I should check for?
Another suspect could be the 100K resistors connected from the input and output points to the ground. I would check whether all four (per chanhhel) are of the same value.
Old 21st May 2006, 04:56 AM   #14
CheffDeGaar's Avatar
- Try to make the 124R resistance variable. So you can adjust the gain and match both channels (Min R value=max gain)
- Check the transconductance of your mosfets : Measure the Vgs of each mosfet @ two different currents using current sources (10 & 20 mA for example) Transconductance is given by Delta(I)/Delta(Vgs).The gain of the BLS depends on the 124R, the Drain resistors and the transconductance...
HTH
/Cheff - Falling feels like flying, until you hit the ground
Old 21st May 2006, 04:08 PM   #15
hifimaker's Avatar
The values of all the resisters were checked and they are correct. I also changed the Fets, and the imbalance still remains.
I just got a topend B&K DMM that has a capacitance function. All the 10uf caps measure to about 10.5uf.... except one on the left channel -(neg) phase, I get no reading at all.
I'm going to order a new 10uf cap, and I bet I'll be in good shape.
-David
Old 21st May 2006, 04:18 PM   #16
Alessandro's Avatar
Select the 750 Ohm resistors (they estabilish the point of work).
Another way is to control the cap on the output, are you sure that they work well ?
Alex
BOSOZ Problem vdi_nenna Pass Labs 52 10th March 2008 06:50 PM
BOSOZ Hum Problem hifileslie Pass Labs 12 18th September 2007 04:28 PM
Bosoz psu problem vit Pass Labs 10 21st August 2005 10:10 PM
BOSOZ PSU problem tcl2 Pass Labs 7 5th July 2004 03:08 PM
Bosoz PSU problem CH2 Pass Labs 3 28th June 2003 04:08 PM
Copyright 1999-2017 diyAudio
