Old 15th May 2006, 06:18 PM   #1
Default Switching inputs on Aleph 5
I want to switch inputs on my Aleph 5 monoblocks between xlr and rca. Some questions: What happens if both xlr and rca is connected, will using one input while the other is connected(and not active) work. What if for some reason both is active, is this harmful?
If one is using relays to switch between the two. Must I turn the amplifier off first to avoid damage to amplifier or speakers?
Old 15th May 2006, 07:58 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
The best explanation I've found is on page ten of the owners manual at the passlabs site. I could repeat Nelson's words but I believe a link to the pdf will hopefully be adequate.
/Hugo
Old 15th May 2006, 08:41 PM   #3
The one and only
Nelson Pass's Avatar
Alephs are pretty immune to swithing effects. Usually there is no
reason to turn off the amp while switching inputs - I never do,
and I've never lost a speaker.
Old 15th May 2006, 08:47 PM   #4
Ok thanks. that will make things simpler.
Switching I2S inputs analog_sa Digital Source 3 15th January 2008 08:40 AM
Not really a DIY question. Popping when switching inputs. mattjk Pass Labs 5 1st January 2005 12:45 PM
rca inputs to aleph-x jrsun Pass Labs 4 19th August 2004 07:13 PM
Aleph P's unblanced inputs and volume Gabster Pass Labs 17 5th May 2002 07:35 PM
Switching Power Supplys and Aleph Amplifiers Mark A. Gulbrandsen Pass Labs 2 16th March 2002 04:20 PM
Page generated in 0.07324 seconds (72.87% PHP - 27.13% MySQL) with 10 queries
