diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   HEATSINK extreme (http://www.diyaudio.com/forums/pass-labs/79632-heatsink-extreme.html)
cumbb 15th May 2006 06:23 PM
HEATSINK extreme
Dear lovers of real high end.
My suggestion to build a heatsink extreme, a heatsink without limits.
Take a radiator, a pump from the pet shop, a aluminium profile and connectors for hoses. Adhesive for metal or silicon will stick the suitably shortened profile with the connectors. This system should be open to de-pressure itself. The highest points of the system should be open or have a valve.
The advantages:
- fastest cooling of the transistors
- quiet resonances; no Kling, Pling, Klirr
- install pieces without distance: shortest paths
- not expensive
- if you need more heatsink, take a second, a third radiator. Or more.
http://img57.imageshack.us/img57/267...g0320qx.th.jpg
http://img525.imageshack.us/img525/8...g0202yb.th.jpg
http://img525.imageshack.us/img525/2...g0259dj.th.jpg
http://img57.imageshack.us/img57/561...g0294zn.th.jpg
http://img300.imageshack.us/img300/3...g0428wt.th.jpg
My systems have a C/W less than 0,05. The size of my radiators is 50cm x 60cm x 10cm.
With best greetings.
C.
moe29 15th May 2006 07:17 PM
what amplifier did you build?
cumbb 16th May 2006 06:58 AM
Hai moe29.
You see - do not hit me, please - the Mosfet/Bipolar Power Follower of Pavel Macura and Ladislav Bunta. In unsymmetrical version. The pre is at moment the ccs-x-bosoz.
C.
powerbecker 16th May 2006 10:01 PM
"do not hit me, please "
Of course not dear Cumbb, because Your f i r s t pic looks somewhat professional!:D
You can also look to this thread:
http://www.diyaudio.com/forums/showt...0&pagenumber=1
Best regards
Heinz!
GRollins 17th May 2006 02:14 AM
I believe I did the first water-cooled thread here. Years have passed. It's still running. I've dumped unimaginable amounts of heat into the thing and never even needed a fan; it's all passive air flow.
I did eventually tear the thing apart and paint the heat exchanger, just so that it would look nicer.
As of a couple of years ago, I've got two spare heat exchangers waiting for a large enough project. They're still waiting because I haven't exceeded the capability of (or worn out) the first system.
Grey
Copyright 1999-2017 diyAudio
