#11 |
Hi cjd,
Once you get into it again I'll try to give you a "hand". Phono fault included. -Chris |
#12 |
Reviving this thread as I need some quick assistance. I'm considering purchasing a PA5 and I recently aquired a pair of Polk Audio SDA 1C's which can't be used in conjuction with a amp that is NOT common ground. I assume the PA5 is common ground but I need to be absolutely sure.
TIA H9 |
#13 |
The one and only
I'm pretty sure it has a common ground on the (-) output.
#14 |
I sold the recievers and amps when new. They were quite nice to listen too. At the time one of my favourite setups to sell, an SR2, OMS2 (or 3), a Revolver turntable and DCM or B&W speakers--DM1600s. (I'd love to get a pair if I could find them and/or afford them). Really a very nice set up--and lower B&W speakers worked well to.
Compared directly to the then current NAD 3240PE, and the HK PM635(?), and a Bryston 2BLP/.5 combination, the Nak ran a close second to the Bryston setup. Yes, the Bryston had better bass. (the 2BLP/.5B was combined into the BP20 or whatever the intergrated was/is called). I recalled the SR2 , and decided to buy one. I think I paid under $50 USD including shipping off of epay. The little reciever still sounds very good. Is it a threshold? nope. But it held it's own against the Bryston pair and at a substantially lower cost. Currently I use it in my bedroom, but hope one day to create a "museum" of equipment in my livingroom. Kinda like pick and play. anyone interested in a more modern look at the Nakamichi SR4 should look here , at the Feb 06 issue.
stew ☮ -"A sane man in an insane world appears insane." |
#15 | ||||
Hi Nelson,
I imagine you have a better idea than most of us, but I'll confirm that you are dead right. H9, Quote:
Hi Nanook, Quote:
But you can't compare it to amps of normal design really and it does have much better mid and high resolution. Yes, it has it's characters, but all in all I'd rather listen to a PA-x over any Bryston of that period (horrid construction BTW).I still use a TA-2 in my bedroom. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#16 |
well, I am, nor ever will be a technician.
I recall the explaination for "Stasis" as follows: basically a high quality input driver (operating in class 'A' or near class'A'), that is used to drive a class 'AB' output. really, kinda like using a class A tube amp as an input to an AB output that uses no or little feedback. Really quite a good idea. And I do love my old SR2, it is an early production one as the ones I sold were after 1989, and the "2" had terrible spring loaded speaker connectors. hmm if low dampening factor than a nice match for my Hemp FR8 drivers
#17 | |
On the Adcom GFA5500, 5800, 5802, 565's and 585's you can tie the negative output terminals together and they can be used with Polk SDA's. I was just wondering if the NAK isn't common ground, could the negative speaker terminals be connected (with approriate size cable) if need be. I sold NAK and Polk way back when and I don't remember this being an issue, but memory can fail so I figured this would be the most accurate place to get the info Regards -Brock- |
#18 |
Hi Brock,
You should be fine. The only issue is that the SDA's force heavier currents between the negative speaker terminals than was thought of when the amp in question was designed. A heavy wire link between the negative terminals is recommended (just like Adcom 555 type amps). We were authorized warranty for both Polk, Adcom and many other amps. I still fail to see why Polk released these darn speakers on the market without very clear warnings. I can't tell you how many customers had to pay for repairs not covered under warranty due to these speakers. -Chris
#19 | |
The one and only
to the load through about 1/2 ohm, which is capable of bypassing the outputs and driving the load directly. I suppose you could think of that as a feedforward approach.
#20 |
Hi Nanook,
I used to be in audio sales and moved into service. Couldn't stand most other salesmen. Anyway, the output of a Stasis amp is class AB, but biased on higher than normal AB. Nelson could give some rough figures off the cuff, and correct me if I'm wrong here (please, feel free to correct me!). The output stage is not contained in the feedback loop. The more output transistors there are run in parallel, the lower the distortion and the higher the damping factor will be. They do not sound as good into low impedance loads as they do into 8 ohm loads. I must say that a Statis amplifier is darn hard to kill. It can be done, and I am impressed when it happens. My only repair of a PA-7 was the unfortunate victim of one of those really large copper box staples that fell inside. It's the only one I ever saw fail. -Chris
| Nakamichi Dac 101?? | dbdell | Digital Source | 7 | 7th January 2010 06:41 PM |
| Nakamichi OMS-2a | XEAGLEKEEPER | Digital Source | 0 | 1st January 2009 12:29 AM |
| Nakamichi CDC-4A | Jimmy154 | Swap Meet | 16 | 25th September 2008 12:30 AM |
| Nak statis | Duck-Twacy | Pass Labs | 18 | 16th April 2004 09:44 AM |
