Old 24th November 2002, 01:29 AM   #1
Send a message via MSN to Mark Hathaway
Default Clarification on SOZ total dissapation please.
Howdy guys,
I'm about to embark on making 4 water cooled monoblock SOZ's at about 30 watts each.
I need some clarification on the total dissapation of the soz topology.
The soz pdf shows dissapation at about 24 times rms watt output, but others have put the number at 15 times.
Anyone who has built one, I'd love to hear your measurements.
Thanks,
Mark hathaway
Old 25th November 2002, 03:45 PM   #2
The one and only
Nelson Pass's Avatar
The article contains a curve showing total dissipation
vs rated output, and from it you will see that the figure
is about 24 times.
Old 27th November 2002, 05:59 AM   #3
Default thanks Nelson (nt)
Old 27th November 2002, 06:24 AM   #4
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Default Re: Clarification on SOZ total dissapation please.
Originally posted by Mark Hathaway
Howdy guys,
Thanks,
Mark hathaway
I think that you are insane.... from the article:
"The prototype amplifier went up to 30W with 45v supply rails and drew about 700W per channel." I forget how inefficient the design is.
What kind of water cooling are you considering doing?
Brian
Old 27th November 2002, 06:34 AM   #5
Default water cooling
5 gallons a minute water flow to a car intercooler with about 300cfm of air flowing through it.
Should keep the mosfets and resistors at about 16 degrees over ambient.
Will make the copper blocks to mount the mosfets and on, resistors are wire wound non inductive hollow ones, will run water through them. (done this before, it worked GREAT)
Mark
Old 27th November 2002, 11:38 AM   #6
PedroPO is offline PedroPO  Portugal
PedroPO's Avatar
Send a message via ICQ to PedroPO
Why do you want so much power with this kind circuit? It's designed to be scalable but that doesn't mean that you should do it with 30W.
If I were you I would try it out first with say 10W and since you can water cool, go up to see if the power gain is with sound improvement.
I made a 5W SOZ and I'm scaling it to a 15W version to see if it is so much better.
I feel that the 5watter is pretty good!
Pedro Oliveira
Old 28th November 2002, 02:12 AM   #7
The procedure I test for SOZ is contrary to the one of PedroPO.
I made two mono 50W SOZ with heavy transformers and heatsinks and then test its sonic feature for a lower power setting by adjusting Varic.
I found that there is some difference at base frequency.
Finally, I settle on 10W rating.
Just for your reference.
An attempt for clarification. Lumba Ogir Solid State 1 4th March 2009 07:46 PM
1G3 Max Dissapation? ak_47_boy Tubes / Valves 1 13th June 2008 04:25 AM
Heat Dissapation Problem LME49720/OPA1632 Preamp artquake Chip Amps 45 2nd June 2008 06:53 AM
PPP OPT clarification PeteN Tubes / Valves 13 2nd November 2007 06:20 PM
Newbie needs clarification MlinarS Tubes / Valves 5 9th February 2005 03:02 PM
Page generated in 0.09565 seconds (78.70% PHP - 21.30% MySQL) with 10 queries
