Old 23rd November 2002, 09:33 PM   #1
Roberto Amato's Avatar
Default SoZ output impedance?
Exactly, what is the output impedance of a standard SoZ??
ciao,
Roberto Amato
Old 23rd November 2002, 09:39 PM   #2
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
i believe it's about 1 ohm...
Mads K
Old 23rd November 2002, 09:50 PM   #3
If the load is 8 ohm the damping factor is 0.5
If this can help.
Old 23rd November 2002, 10:06 PM   #4
My load (RoyalDevice Laura speakers) is "realistically" 6ohm. How do you get dumping factor out of speaker loading impedance?
Actually my SoZ (5.5w) does a great job in driving the Lauras, which are specifically designed to work best on no FB, low dumping factor amps... so I'm asking for mere desire of knowledge; besides, a friend expressed the thought the SoZ has a 16ohm output impedance... and that frankly, it's hard to believe.
ciao,
Roberto Amato
Old 23rd November 2002, 10:37 PM   #5
Mad_K's Avatar
oups! messed up...
-too tired, too late -sorry..
Mads K
Old 23rd November 2002, 11:05 PM   #6
I learned that damping factor on son of zen is the load resistor
divided by the sum of the drain resistors.
In your case is 6/ (8+8)=0.375
Old 23rd November 2002, 11:14 PM   #7
Thanks, Stefano, things are getting clearer...
ciao,
Roberto
Old 25th November 2002, 03:46 PM   #8
The one and only
Nelson Pass's Avatar
In other word, SOZ has very little damping factor.
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Output impedance overdrajv Tubes / Valves 8 5th March 2008 05:54 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Output Impedance? ble0t Parts 4 19th January 2006 05:45 PM
Low output impedance pre miguel2 Tubes / Valves 13 23rd July 2003 09:51 AM
Page generated in 0.08636 seconds (75.79% PHP - 24.21% MySQL) with 10 queries
