Old 9th May 2006, 02:34 PM   #1
Default X250 stay cool! Normal?
I purchased an used X250 to drive my TAD Horn speaker with impedence 8 ohm and sensitivity 103db one month ago. I found that the X250 stay cool even after running for 8 hours. The heat sinks temp. rise to less than 10 degreeas C above room temp.
Any simple way to check whether I should send my X250 back to local dealer for bias-checking?
My TAD Horn Cinema
Old 9th May 2006, 04:39 PM   #2
The one and only
Nelson Pass's Avatar
The amplifier should run about 25 deg C. above ambient.
More practically, the heat sink temperature should be on the
borderline so that you can put your hand on them for about 5
seconds.
Old 9th May 2006, 04:55 PM   #3
Dear Mr. PASS:
Thanks for your immediate reply!!
After Non-stop running for 8 hours, the heat sinks temp. of X250 is really low, just like the power is not ON!! The VU meter stay at 10 o'clock all the time!
Would you mind telling me whether X-series Amp should receive regular BIAS check-up ?
My TAD Horn Cinema
Old 9th May 2006, 08:26 PM   #4
The one and only
No, a regular bias check up is not required, but all our amplifiers
are biased for approximately the same temperature, so anyone
can apply the 5 second temperature test to decide whether
their amp might need to be looked at.
Circuits occasionally fail, and we do run across pieces in the
field that have had their bias potentiometers tweaked by users.
stay-on switch CommanderZero Parts 0 17th June 2006 09:51 AM
help me stay alive (mains) travis Everything Else 12 20th June 2003 08:54 AM
Dr. Bob says: Don't be a fool stay in school Fred Dieckmann Everything Else 1 1st April 2003 10:31 PM
building amp every one should stay tuned jleaman Everything Else 0 13th April 2001 05:45 AM
Page generated in 0.07767 seconds (71.10% PHP - 28.90% MySQL) with 10 queries
