ok, well
i have this Harman Kardon pm645vxi http://www.harmankardon.com/specific...645VXI&sType=H and i was wondering, should i launch myself in making a Aleph (2 or 3) or should i keep my HK, do you guys think i would get a major improvement by having a aleph? Considering i could also change caps i in the HK with some better ones.. |
#2 |
diyAudio Retiree
Most definitely keep the Harman Kardon
#3 |
donīt forget you also need a preamp for the Aleph.
william P.S. sell the Harman
een ooievaar is geen konijn want zijn oren zijn te klein! |
#4 |
Sorry Illianh for being off topic here!
Wuffwaff, Iīm planning on building an aleph3 next. Why is there need for a preamp with the aleph? Isnīt the input impedance high enough for just connecting a pot? Jens |
#5 |
I think the alephs don't have as much gain, so to drive them to thier limits, you need a preamp.
#6 |
unless you want to be part of the T(tinnitus) gang you need some volume controle, don't you ?
alleen vragen |
#7 |
Jens,
with only 20dB of gain it will be quite difficult to use a passive preamp unless youīve got really efficient speakers. My preamp has 6dB of gain and with some records / cdīs I need to turn up the volume all the way. william
#8 | ||
I thought the Aleph is designed to be an independent power amplifier which means to me that itīll be driven to full for example by a CD-Player. Is the ZenV4 the same?? (donīt beat me Iīm class a newbie and reading Nelsonīs patents is on my "soon-to-do-list") So I have to build some preamp first heh?......... Thanks in advance |
#9 |
Hi Wuffwaff,
OH Iīm a slow writer! OK, Iīve taken in I need a preamp. As I said Iīll still have to read a bit before I build it. Which preamp are you using? DIY? thanks Jens PS:Where did you get your big caps for your new aleph?? |
#10 |
The one and only
You can crank up the gain via the feedback loop as much
as you like on any Aleph. |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.09402 seconds (78.24% PHP - 21.76% MySQL) with 10 queries |
