sorry for starting new thread, but I found lot info about how to measure and mach mosfets but how to measure and match resistors. throught multimeter can not measure 0,22-1ohm precisely.
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!.. |
#2 |
I think you need an ESR meter.
Greg Erskine |
#3 |
what is esr meter? my multimeter measures Volts,ampers, inductivity, capacity,,temperature, diode mode, hfe mode.
somehow I thought that I need to build some power suply to hook there resitors and measure it across..
#4 |
Lightning In A Bottle
A practical way would be to connect in series a higher value resistor like 10R or 100R that your multimeter can read. Make sure you measure this resistor first. Your meter should be able to read 2 to 3 decimal places.
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
#5 |
Build a current source, somewhere between 100ma and 1a. Then just measure the voltage across the resistor (~22mv-1V, depending on resistor value and the current you chose), plop the values into ohm's law and...
You don't even need to calibrate the current source or use ohm's law to find the actual value, if you're just matching emitter resistors. Just match voltages. |
#6 |
thanks for quick reply, could You post simplified schematic for this current source, I have no imagination what it is. some dc voltage shortened with this resistor or not?
#7 |
Q1 can be any medium/high power transistor. Q2 can be almost anything. R1 should be between 0.1 and 10. R2 should be Vcc/((0.65/R1)/Hfe'q1)*2, or around 10 to 100 times larger.
P.S. Sorry about the image quality, I compressed it rather quickly without thinking and compressed it into nothing (20kb from 420kb). |
#8 |
Looks like Sponge Bob has killed another thread. |
#9 |
ok Tim thanks I think I will not blown more transitors with this circuit.its enought at this month.
am I too naive to thinking this way- I solder input terminals for source resitor can be solder/desolder without dismounting pcb from heatsinks. I just turn on amp after 10 sec measure voltage arround this resistor and write value(lets say 0,4-0,5V) and then try to match pairs . this would be pretty ok?
#10 | |
An ESR meter is used to measure the ESR of an electrolytic capacitor, but it also can be used to measure low valued resistors, typically in the 0.01 to 99 ohms range. I use mine for this purpose and it seems to be accurate. regards
Greg Erskine |
| WTB: 1ohm 5 w Mills resistors | paulyang | Swap Meet | 3 | 8th December 2005 06:59 AM |
| How to measure resistors below 1R | bigpanda | Parts | 6 | 19th June 2005 04:02 PM |
| SMD resistors measure badly after soldering? | motherone | Parts | 18 | 4th March 2005 03:57 AM |
| Source info for 8ohm/1ohm Dale (JAN) resistors | psarin | Pass Labs | 1 | 19th November 2001 04:33 AM |
| Page generated in 0.09214 seconds (81.37% PHP - 18.63% MySQL) with 11 queries |
