A less used approach
Old 21st January 2003, 12:51 PM   #11
SuppersReady is offline SuppersReady  United Kingdom
SuppersReady's Avatar
Default Suitable?
Following on from the original question of this thread, I have found a local (well, it's in the UK at least) source. http://www.audiocom-uk.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=A&Product_Code= AirCoreCU1.4
Would these be suitable for the PSU described earlier? The resistance seems higher than some of the American sourced chokes of similar guage. The transformer (one per channel) will be a 500VA device (ILP, I believe)
Cheers
Paul
Old 21st January 2003, 09:05 PM   #12
Default Oops!
Or you could try this.
http://www.audiocom-uk.com/Merchant2...e=AirCoreCU1.4
Better luck this time
Paul
Old 22nd January 2003, 07:27 AM   #13
uli is offline uli  Austria
Default Re: Oops!
Paul
Hi Pauil,
IMHO these are Xover inductors!
I wouldn´t use them in a high DC-Current Powersupply!
You may take a look at www.rs-components.com
C-R-C-C is what I use 3 times 22mF with a 0R22/25W Resistor
for Aleph2 -kind amps.
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 22nd January 2003, 11:24 PM   #14
So are the inductors from Zalytron as I understand, yet I have seen these recommended regularly on this forum for PSU use. Hence my interest in these parts.
Have checked wire guage since, they don't seem much of a bargain anymore. Are there any more realistic UK sources out there? Net searches don't seem to produce many useable results.
Paul
Old 25th January 2003, 08:35 PM   #15
I've never used inductors in my PSUs before hence my caution in selecting them. This inductor appears to give a good balance of price/DCR/wire guage. Shipping shouldn't be too bad from Europe.
?http://www.intertechnik.de/cgi-local/shop4/shop4_erg.pl?0&&Elektronikbauteile&&Spulen&&Rollen kernspulen&&none&&29
Article number:1340266
My question: Will these inductors be up the task if used in the PSU outlined at the beginning of this thread?
Help on this will be greatly appreciated!
Cheers
Paul
Old 26th January 2003, 08:30 AM   #16
Thumbs up DC-current
Hi Paul,
normally those inductors (especially with some metallic core)
are NOT intended for use with heavy DC-current flowing thru
that device. But exactly this are you doing in a PSU. You can
build them on your own ore look for Switch mode PSU
inductors. www.hammondmfg.com/195.htm is a source for what you´re looking for...
Uli
Old 26th January 2003, 10:16 AM   #17
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default less used
Hi Paul,
You may have already decided how to do it, but for a C-L-C I would put all C after the L in the amp box. That way you have short wires to the load so the caps can source the best they can. The cabling between the amp and supply becomes part of the L, which will make the influence of the cable very small. The spikes and other junk filtered out by the L will actually appear across the L, so you want to keep that out of the amp box. Lastly, the first C will be close to the rectifiers so rectifier noise will be less likely to propagate throughout the system.
Jan Didden
Old 27th January 2003, 05:47 AM   #18
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
It seems to me that putting some of the 2nd "C"
in the psu box will have at least one benefit, which
is that interupting the circuit won't generate a big
spike.
pass/ - getting sleepy after many posts, glasses of wine,
lounge music CD's
Old 30th January 2003, 12:16 AM   #19
Thanks everybody,
Finally ordered the inductors after emailing wuffwaff who has used the same type without problems reported. Chose the Intertechnik luftspullen, 3.3mH. The DCR is high but since I'm using a 30-0-30 trafo I can lose a volt or two anyway.
Jan and NP, food for thought. Positioning of the caps re:spikes was not something I was aware of. Reading back through threads, some people argue for a small capacitance before choke followed by larger capacitance. This suggests that C-L-C-------C-C would offer the 'best' compromise.
Any thoughts?
Cheers
Paul
A less used approachHide this!Advertise here!
rational approach traw Multi-Way 2 15th August 2006 08:39 AM
Active 2-way, best approach to x-over under 1k? Greggo Multi-Way 3 14th July 2006 05:52 PM
A different sub approach, will it work? Zero One Subwoofers 15 1st May 2006 04:06 AM
here's my approach hitsware Solid State 2 13th November 2004 05:54 AM
Copyright ©1999-2017 diyAudio
