power supply issue
hi, everyone.
i'm going to build two aleph 5. my problem is i already have a 500VA and two 300VA transformer. all of them are having 36 - 0 -36 secondary voltage. after the bridge, the DCV will be ~ 46 - 0 - 46. quite high for the amp. So, what part of the circuit on the amp do i need to modify? THANKs :) |
If you need to take the voltage down, I suggest coils in series
with the primaries on the transformers. |
Thanks for the advice.
Is a great honor, having your replie. Mr Nelson. i had found a solution to my problem. The aleph 4 uses the same DC value that i have from my PS. So build a aleph 4 but with less output devices, as the trans of mine is only rated at 500VA. |
Won't that alter the impedance of the transformer (on the secondary side) considerably, compared to a number of diodes, if the voltage doesn't need to be lowered that much (general consideration)? Jennice |
It works for the Alephs since they have a net constant draw
from the wall, so a given impedance coil will reliably lower the voltage. This is not true of Class AB (and D) type amplifiers. |
:bulb: Ahh... THAT's the catch! Class A operation.
Thanks for the feedback, Mr. Pass. Maybe you have a good idea for my little problem (and reason for reading this thread). I have plans about a Class D, design, where the currrent draw will obviously vary immensly. I'd like to lower the idle (no-load) output voltage of my supply a few volts. It's rated voltage is fine for my planned class D modules,, but it's idle voltage is on the high side. Could a simple constant current source make this controlled load (I know it's not in the line of power saving class D design, but it's not about conserving power), or do you have a better idea to avoid the "no load" condition? Jennice |
What advantage is there in using a coil on the primary side, compared to a secondaries CRC arrangement ?
http://www.diyaudio.com/forums/showt...418#post926418 Kirchhoff's 1st and 2d laws, wattage in is wattage out. In Mr Dury's words: Hit Me. (textbook slaps only) The Scot worm remark was pretty funny,Jennice. |
To Jacco:
My "Scot worm" remark? Uhmmm-... thanks, but where, what thread **Puzzled** |
Of course i believe you, here goes: http://www.diyaudio.com/forums/showt...083#post930083 |
Jacco:
Thanks. I was confused since I didn't recall any worms in this thread, or your participation in the other thread. Thus my confusion. I felt that AndrewT was making a lot of noise before thinking it through, and that I was verbally attacked by him without him being able to prove me wrong. He went after the player, not the ball (the subject), and I didn't feel an urge to be very polite to him. :devilr: He also made me wonder what he was really after. He gave an example with an unknown resistor, and a "reference" of which he even described the materials and the design of the trimming method. Knowing all that, I would assume he also had data on the inductance value of this reference, which is much more obvious than finding a describtion of it's value trimming method. -- So his contribution seemed more like the result of having a bad day, than a serious contribution tio the original question: "Is it possible to find out if a resistor is non-inductive?" |
| All times are GMT. The time now is 07:11 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
