Old 5th May 2006, 02:15 AM   #1
hifimaker's Avatar
Default Anyone built a Pass D1 I/V for a TI1794 or TI1794 DAC?
I understand that the current output of the TI1792 DAC chip is higher than other DACs. Has anyone had success buildign a D1 I/V for these newer TI DAC chips?
-David
Old 6th May 2006, 06:04 PM   #2
hifimaker's Avatar
The specs on this BB/TI 1792/4 chip look great. I'm surprise no one has implemented a DAC with a Pass I/V stage yet.
-David
Old 6th May 2006, 08:56 PM   #3
I love D1 stage . And implementet at least with 4 dacs . Will need to modify the biasing network a bit if the dc point of the dac is different from 0 volt . An example is the Philips tda 1545 wich requires 3.3 volts as dc working point.
Currently I am using the lovoltech j fet in that circuit . I am very happy .
Old 6th May 2006, 09:11 PM   #4
acaudio is offline acaudio  Germany
Stefano,
I´m currently building my D1 stage with different options.
I´m still no really lucky. my CDP (shanling CD-S100MK2) has a PCM1738 inside. This chip seems to work best into a "virtual" ground, the common Voltage is set to 2,50V.
See this picture, and thread: http://www.diyaudio.com/forums/attac...amp=1081271528
D1 output stage and PCM1738
I tried already a few different adjustments and I thought it were good, but after long listening I´m sure, I´m missing dynamic.
Would you please posting your lovoltech D1? I´m working at a 2SK389 based D1, very different to original. I thought too about LU1014d, but those needs a lot of current to operate in "triode region"
Best Regards
Adam
http://www.acaudio.de
Old 7th May 2006, 12:50 PM   #5
No, really also in a single ended set up I like dynamics , very correct . But compressions and dynamics depends on power supplies implementation and a number of other things.
With j fet (lovoltech)there is a step forward by my point of view ,and often I can see the mixing consolle very clearly . It is a nice sensation .
I wasnt so happy with 2sk s .
Absolutely the lovoltech require matching between channels . The difference is quite audible and not at all subtle.
I started by inserting jfets in the same circuit , just adjusting the bias ... and all seems to work pretty well .
Old 7th May 2006, 04:21 PM   #6
hifimaker's Avatar
Thanks Stefano for your insights.
Could I ask, what DAC are you using?
-David
Old 7th May 2006, 04:38 PM   #7
hehehe I have the Philips tda15145 but every part of the circuitry has separated supplies , laser motors drivers and clock included .
I can assure you that it works very very good .
I had also nice performances with sony current pulse , in that case in a balanced configuration .
The philips is 16 bit converter , sony is tipically 1 bit.
Old 8th May 2006, 02:46 AM   #8
agent.5 is offline agent.5  United States
Assuming that I have 0 volt out from the DAC, what do I have to change to the circuit to use Lovoltech Jfet instead of IRF610. My thinking is that I need to change the two 1.5K resistors to a different value to bias the Jfet? The schematic that I am looking at is attached.
Old 8th May 2006, 09:37 PM   #9
relder's Avatar
Send a message via Yahoo to relder
JFET Vgs is negative, unlike MOSFET, so instead of tying r5a to +30 tie it to -30. The 1.5K resistors control gain, not bias, to change current bias change the 3.3K resistor.
Old 8th May 2006, 10:19 PM   #10
hifimaker's Avatar
I seem to recall someone built a D1 I/V stage with Jfets recently, Let me see if I can find it.
Would be very cool.
-David
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Paging Mr. Pass, Mr. Pass pull my finger please. khundude Pass Labs 2 5th December 2008 04:11 AM
Question about power amp built in high pass filter crippledchicken Solid State 0 22nd October 2008 06:09 PM
non-Pass amps youv'e built/heard BrianL Solid State 49 5th July 2005 05:59 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
Page generated in 0.10873 seconds (77.45% PHP - 22.55% MySQL) with 11 queries
