Hi All,
I have a problem with my Threshold SL-10 and I'm not sure what the cause is. From an initial startup the mute relay switch will function normally and unmute the preamp after about a 45 second warm up and the preamp will function normally, but after a couple of minutes or so the relay will click and mute the preamp again and it will not unmute anymore unless I shut the power off and let it sit for a few minutes, then the relay may or may not unmute when I re-apply power to it, if it does happen to unmute, the preamp may function normally for maybe 10 to 30 seconds and the relay will mute the preamp again. Also when it does unmute the sound will come on 1 or 2 seconds before you hear the relay click. Any input to what might be causing the relay to mute the preamp for no reason and how I can solve it would be greatly appreciated. |
#2 |
I don't have that part of schmtc,but first you can try to change (usually just one) elco in relay dedicated trigger circuit.......simpler: find transistor for relay powering;look for all electrolytics around;change them with similar values
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
Without a schmatic its tough to figure out which part does what and I'm not wanting to do a process of elimination to find the problem. It seems that it has something to do with what ever triggers the relay to unmute the preamp. What ever signal trips the relay to come on also shuts it off, you can plainly hear it click when it mutes the preamp after a few seconds of normal operation. Perhaps the one and only himself Mr. Pass could shed some light on what I need to look for and why the relay is clicking off when it should be on. Or perhaps someone could tell me how I can get in touch with Jon Soderberg for some help. I Would really appreciate any help I can get.
| Muting relay problem | decky | Solid State | 23 | 23rd March 2008 07:29 AM |
| Marantz CD85 Output Relay problem | kokkeong | Digital Source | 3 | 16th November 2007 09:35 PM |
| Marantz 1180DC Relay? Problem, HELP | Bruce | Solid State | 9 | 22nd September 2007 08:54 AM |
| Relay spark problem | Dxvideo | Chip Amps | 26 | 30th July 2007 07:32 PM |
| Page generated in 0.07104 seconds (71.25% PHP - 28.75% MySQL) with 10 queries |
