I am using Art Dio, which has about 7-9v of output, as the source. Is 10K still the best value for a simple passive preamp (RCA-in+pot+RCA-out)? Or should the impedance be higher or lower? Some passive preamp schematics have a 1k resistor before the pot, why? Thanks!
#2 |
Hi, It depends on the impedance of the amplifiers input and your preamps output impedance, if the i/p z is about 40k you'll be o.k, if it's significantly lower, you 'll have to keep the interconnects short ( shorter the better anyway)
as the capacitance of the cable will filter off some of the hf. As for the resistor in the schematics, my guess is it's a law faking resistor to make a linear pot behave like a log pot, Audio Synthesis used to do this. No doubt someone else can give you a better technical explanation. Jules |
#3 |
Thank you. The input impedance is 22k. My cables are very short (10 inches) and have very low capacitance. In my case, with the output being strong, would you still recommand a 10k pot or a pot of other values? Thanks!
#4 |
Banned
#5 |
With such short cables, I can't see a problem,
do you know the output Z of your source? if it's nice and low You could go to a 5k pot ( stepped attenuators sound better, but that's perhaps for another day). Jules |
#6 |
DACT is a nice attenuator and I'm using one in by BOSOZ right now.
They have a design for a pasive preamp using their attenuator. wiring Diagram http://www.dact.com/html/wiring_a_ba...reo_passi.html DACT Passive preamp article http://www.dact.com/html/passive_preamp.html Complete DACT passive preamp design by one of their customers http://kotiweb.kotiportti.fi/audiovideo/DIY/preamp1/ -David |
#7 | |
Banned
Id have to say that dact's make to much noise and they wear out to fast. |
#8 |
I have the DACT2 and it is very quite. The Emla switch is of very high quality. The thing is dead silent while turning it to adjust volume.
There's a clear plastic shell around each deck of the switch and the machining and finish of the gold plated contact points look great. Don't know what to say other than Elma's are great switches. -David |
| F1 and a passive preamp? | roscoeiii | Pass Labs | 10 | 10th May 2009 12:55 AM |
| passive preamp | mjh77 | Analogue Source | 4 | 14th August 2004 10:06 PM |
| Passive Preamp | Rarkov | Analogue Source | 77 | 15th April 2003 06:51 PM |
| Passive preamp | Flemming J P | Everything Else | 7 | 5th November 2001 09:40 AM |
| Page generated in 0.08063 seconds (86.62% PHP - 13.38% MySQL) with 10 queries |
