The New-Tron
The New-Tron
Old 27th May 2006, 08:01 PM   #71
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The New-Tron
Yes, this is definitely a Class A circuit.
As to the cascode, you can approach it either way, I don't think
it's going to make a lot of difference. Self biased JFETs are
elegant, but you have to take the voltage they offer.
Old 27th May 2006, 09:14 PM   #72
EUVL is offline EUVL  Europe
May I ask for one more hint ?
Suppose I only want 10-15W Class A (just to drive tweekers), and I want to use Loveltech Power JFETs with Cascode as output, like Grey is proposing. I guess I would be biasing single JFET at 1.3A (2 Power JFETs per channel). Would I still be able to use the triode parts of the curves ? I have no Power JFETs on hand yet, and there is insufficient information on the datasheet. What would be the best cascode voltage ?
Many thanks in advance,
Patrick
Old 27th May 2006, 10:09 PM   #73
The one and only
The New-Tron
Of course. You get to the triode part of the curve by operating
at the lower voltages, and the cascoding can easily be set for
any operating point you want. It's just lucky that the spot you
want is 2-3 volts or so, so the dissipation will be low on the JFET.
Old 28th May 2006, 05:08 AM   #74
Any chance of publishing some measurements (Id vs Vds for various fixed Vgs) around that region ?
Most grateful,
Patrick
Old 29th May 2006, 03:58 AM   #75
jh6you is offline jh6you
Account Disabled
Originally posted by Nelson Pass
Kirchoff's Law dictates that the circuit will not work unless there
is some DC attachment from the input circuit to the output
circuit to allow a difference in drive current to the output devices.
Aha . . . Kirchoff's rule . . .
The basic is almost same as shear flow analysis with multicells we are working on it daily.
By the way, I was always confused if the simultaneous linear equaions are more than two. Never improved yet . . .
JH
Old 30th May 2006, 05:10 PM   #76
The one and only
The New-Tron
You are in the region where it varies quite a bit. If you check
ZV9, you'll get some incomplete information.
Old 2nd June 2006, 08:47 AM   #77
> You are in the region where it varies quite a bit. If you check ZV9, you'll get some incomplete information.
Had done so already before asking. Guess I just have to wait until the JFETs arrive, whenever that might be.
In the meantime, this is the first attempt for the power JFET version. Of course you are right, the MOSFET version published earlier here has very little gain. This should have about 30dB at 4 ohms, and is, at least according to quick hand calculations, stable to over 1MHz.
The over-current protection is probably not quite sufficient, but I have not figured out an elegant way of doing that yet.
Should I expect expect quite a bit of thermal drift for the Power JFETs, bearing in mind their very high transconductance ?
Patrick
File Type: pdf 2 stage circlotron pjx v1 simplified.pdf (76.0 KB, 595 views)
Old 2nd June 2006, 02:33 PM   #78
Firstly my apologies for posting the wrong schematics. It was of course not the one with Power JFET, but the previous MOSFET circuit.
It had taken some time and I still could not make the file small enough for posting, so we'll have to do it in two halves.
This is the overall view.
Patrick
File Type: jpg 2-stage circlotron pjx v1 simplified.jpg (76.9 KB, 2029 views)
Old 2nd June 2006, 02:34 PM   #79
And the left hand half in pdf.
Right hand half is identical but mirrored.
Patrick
File Type: pdf 2 stage circlotron pjx v1 simplified hlf.pdf (73.3 KB, 537 views)
Old 14th June 2006, 06:37 PM   #80
gl is offline gl  United States
Hi Grey,
How is the development of the New-tron going? There have been lots of ideas floating around on this thread. Have you made any further updates or had any further progress? Thanks.
Graeme
The New-TronHide this!Advertise here!
Tron Seven reinhard Tubes / Valves 2 30th April 2008 12:26 AM
Tron Syren analog_sa Tubes / Valves 2 13th April 2005 09:05 AM
