Old 26th May 2006, 10:12 AM   #61
djk is offline djk
djk's Avatar
You may find the resistors to ground may be a much higher value, 500 ohms or so. I think they only need carry the gate current for the outputs.
Old 26th May 2006, 10:26 AM   #62
EUVL is offline EUVL  Europe
I think the discussion is not what value they should be (could even be 1k or 10k), but rather how to get rid of them altogether, and perhaps why they should be disadvantageous.
As promised the revised schematics.
Patrick
Old 26th May 2006, 02:05 PM   #63
Account Disabled
Originally posted by EUVL
jh6you,
How could we address you by name ?
JH
Old 26th May 2006, 02:29 PM   #64
flg is offline flg  United States
flg's Avatar
Well, there was a question some posts ago and recently regarding why we need those 2 Rs to Gnd... The 2 power supplies that supply the output circuit are floating. They have no Gnd connection. Most discussions of drivers, refrences some drive voltage to ground. Drive voltage refrenced to Gnd will do nothing to the output. The drive needs to be Gate to source. Hence, the Rs allow a gate to source voltage return path while still alowing the output supplies to float.
My circuit has no feedback and it will not work without the Rs. Transformers were the original method to drive this thing. They supply an isolated gate to source drive.
And then ther is me. I'm the one who wants to use some parameters that are most important to make the Rs in my circuit optimum. I've just been putting it off for bench evaluation. I beleive they will be most important on a real circuit with imbalances and offsets, etc. All the perfection of the simulator is not pointing out anything particular to help me understand??? I have simulated small value Rs in 1 source to see what happens. The offsets at the output will be lower with the lower value Rs...
Did I help anyone understand Circlotron, and of coarse New-Tron any better??? Yes it's weird. I don't even think it's one of those agreed upon Class A or AB types of classes...
Old 26th May 2006, 02:40 PM   #65
flg's Avatar
Grey, I have a question regarding something I've seen but I just wondered how your prototype would react... What happens when the load increases. Say down to 4 or 2 ohms. Does one side off the amp just keep turning on, in a class AB sort of way???
Old 26th May 2006, 03:08 PM   #66
Account Disabled
I once again looked into Patrick's . . .
If there are those resistors, I think that the values closer to the speaker impedance would better help to reduce the DC offset . . . but . . .
JH
Old 26th May 2006, 03:33 PM   #67
Account Disabled
I was thinking about this . . .
Old 26th May 2006, 05:15 PM   #68
flg's Avatar
I don't think that will work jh6you. You need a Drain load don't you. You have a battery??? If I see that right? you are trying to get a common source configuration to work? I have not tried that yet... There are also some inductor loaded follower designs that have gain???
Old 27th May 2006, 07:05 PM   #69
The one and only
Nelson Pass's Avatar
A few thoughts:
Kirchoff's Law dictates that the circuit will not work unless there
is some DC attachment from the input circuit to the output
circuit to allow a difference in drive current to the output devices.
The 2 resistors across the load provide an arbitrary virtual
ground for this, and we see that the currents coming from the
Drains of the input devices as well as feedback currents must
flow through these resistors on their return path to the
input stage. As such, they should be as low a value as
practical, but not so low that they load down the output
undesirably. My own thinking is that 22 ohms would probably
be that lowest practical value.
The performance of this technique will then hinge on the power
supply rejection and common mode rejection of the input stage,
so that cascoding and a high quality CCS will be important.
As to AB performance of this a circuit - forget it. There is not
enough feedback to give low distortion at the crossover point.
Old 27th May 2006, 07:37 PM   #70
Nelson,
Many thanks for the analysis.
Meaning pure Class A ?
(Just want to make sure I understand correctly language wise, by no means questioning the statement.)
Would you use a self biasing cascode (like e.g. J174 with high Idss which would give about 5V Vds across the diff pair), or at fixed voltage (e.g. ZVP3310A with gate at -7V wrt. Gnd ? What are the pros & cons ?
Patrick
Tron Seven reinhard Tubes / Valves 2 30th April 2008 12:26 AM
Tron Syren analog_sa Tubes / Valves 2 13th April 2005 09:05 AM
Copyright ©1999-2013 diyAudio
