what schottky have been used?
Old 29th April 2006, 11:27 PM   #1
freakyone is offline freakyone  New Zealand
Default what schottky have been used?
hello Team!!
Ive read Schottky have the best sound chararistics.
Thinking of using MBR1645 for my dual bridge AX-100
but these are rated at 16A, 45v TO-220AC
Would like to go larger but having problems with the 3 pin schottky Diodes
I can find common cathode but no common Anode to make up a bridge.
IS 16A forward current enough on the MBR1645?
Me thinks it is
Thanks in advance
Dan
Old 29th April 2006, 11:41 PM   #2
forgot -Will be using soft start!
Old 30th April 2006, 06:27 AM   #3
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Dan,
As far as I know, there is no common-anode 3-pin schottky. To make a two unit full bridge, you will need to use the MUR1620CT and MUR1620CTR (common-cathode and common-anode, respectively). These ultrafast dual-unit rectifiers are made by OnSemi. I have used them in SMPSs for several years now, with good success.
Same types you would find in most car amps with PWM DC-DC converters.
Hope this helps!
Steve
Old 30th April 2006, 06:47 AM   #4
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
How about switch diods,like Byv26 or Byw95 wich im using,any diffrence in sound?Thowe not as powerful as 16A.
Regards Åke
Old 30th April 2006, 07:55 AM   #5
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
I´ve used STPS 80H100TV in my Aleph-X. One piece = 2 Schottkys
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 30th April 2006, 08:45 AM   #6
Hello William
Have you priced these puppies!!!
If i remember correctly you purchased from the Trading Post.
Old 30th April 2006, 09:07 AM   #7
NP said he is using BYW99W-200 in the XA series.
These are three pin common cathode
Just how do you make a bridge with only common cathode??
This is causing some headache!!
Old 1st May 2006, 08:38 AM   #8
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Put the (dual) diodes in paralell...
Mads K
Old 1st May 2006, 10:29 AM   #9
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
Use 3.
Greg Erskine
Old 5th May 2006, 09:18 AM   #10
How does this look?
Cheers in advance
Dan
what schottky have been used?Hide this!Advertise here!
Bad Schottky?? pjanda1 Tubes / Valves 11 27th January 2009 12:21 AM
Schottky & Co. Calamaro Solid State 7 24th August 2008 06:53 AM
connection of schottky freakyone Parts 7 9th April 2006 01:25 AM
SiC Schottky rectifiers. TugaTweaker Tubes / Valves 14 29th June 2005 07:57 AM
