Hi!
I have a 24-0-24V 800VA transformer and I want it to power my Aleph3 boards... After the caps and without load (boards not connected Also, the FETs I use are IRFP048... Can this be possible to work without burning?! With 15-0-15V transformer (+/- 21VDC) the heatsink get Now I wonder what can happen with +/- 32.5V... Any help?! |
#2 |
1. It will get much hotted.
2. The outputs are rated for 55 volts and is close to exceeding that with the 64 volt swing - losses for the rails. http://www.irf.com/product-info/data...a/irfp048n.pdf 3. I would stick with the 15-0-15 and enjoy the music. 4. It woul be good for an Aleph 5.
MikeW |
#3 |
hi
for (canada) power house is 120vac take a normal transfo 250va 24vac 10A (with or without center tap) wired like a autotransformer to get 100 or 110vac and in my test i get exactly +-25v with 100vac on my big 750va toroid for my aleph 3 and 100vac give a more low noise toroid for europe often power house is 240vac maybe a 48vac 5A do the job bye |
#4 |
i forget :-)
i get +-25v with 100vac with load connected 4A (2 channel with just 1 transfo) |
| Want: Toroidal 800VA 2x30VA | thim | Swap Meet | 3 | 5th April 2009 01:10 AM |
| FS: Antek Torroid 40V x2, 18V x2, 800VA | dweekie | Swap Meet | 0 | 7th July 2008 12:24 PM |
| FS 800va transformer | woody | Swap Meet | 2 | 25th April 2008 11:57 AM |
| 2 trafos 230V/2x18V 800VA | DarkOne | Swap Meet | 2 | 15th January 2008 12:50 PM |
| 800VA transformers on UK e-bay | bigparsnip | Swap Meet | 0 | 14th February 2004 04:20 PM |
| Page generated in 0.07001 seconds (69.64% PHP - 30.36% MySQL) with 10 queries |
