#41 |
To set SW2 input selection see following pictures.
MC selection SW2 1OFF SW2 2 OFF SW2 3 ON SW2 4 ON MM selection SW2 1 ON SW2 2 ON SW2 3 OFF SW2 4 OFF Photo of SW2 presets for MM selection |
#42 |
SW2 presets for MC selection.
Be carefull of the polarities with + and - they are not all in the same direction. |
#43 |
SW1 is used to set the load.
The easiest is to use 1 switch. SW1 1 R6 1000R SW1 2 R7 825R SW1 3 R8 475R SW1 4 R9 249R SW1 5 R10 100R SW1 6 R11 47R5 SW1 7 R12 24R9 SW1 8 R13 10R You can of course use multiple resistors to parallel them and get values in between. I wont make a chart of this. You can see the Aleph Ono user manual. Calculate yourself or use a multimeter. |
#44 | |
Electrons are yellow and more is better!
2 That may be true but I haven't got any problems with massive groundplanes and machine soldering.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#45 | |
1. Ignorable 2. It does anyways 3. High inductance/impedance 4. Compromized (frequency limited) shielding capabilities
Mads K |
#46 |
One reason I used it was that the Pearl had the same type of ground plane.
#47 |
I figured that
Mads K |
#48 |
If I'm not mistaken Nelson had this because the pcb manufacturer wanted to save copper.
#49 |
Save copper? How do you mean?
Mads K |
#50 |
Solid groundplane, more copper.
| For Sale: Pearl phono preamp | Boban | Swap Meet | 8 | 26th April 2009 03:04 PM |
| pearl HELP! | d to the g | Pass Labs | 24 | 31st May 2007 01:56 PM |
| Pearl Phono Preamp | bfard | Pass Labs | 2 | 26th March 2007 03:25 AM |
| Output capacitor for Pearl Preamp | dkimble | Pass Labs | 4 | 17th July 2002 05:47 PM |
| Pearl phono preamp questions | Ren | Pass Labs | 19 | 22nd May 2002 01:17 PM |
