diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Aleph 30 Help (http://www.diyaudio.com/forums/pass-labs/78372-aleph-30-help.html)
eapavant 25th April 2006 01:41 PM
Aleph 30 Help
Ok I need some help. I am using Perer Daniel's a30 boards. First my ps is +/- 31vdc under load. I am not sure if this is my problem or not. When I start it up I get +31vdc on R14, -31vdc on R39 and +30vdc on R27. I have no idea how I managed that. Any ideas would be a big help.
hifimaker 25th April 2006 06:16 PM
If you are building an Aleph30 for 30watts at 8ohms, the rail voltage should be 25vdc. You might consider adding more resistance if you are using a CRC arraignment in the PSU.
Here's a link to the PSU simulation I used and it worked out well.
http://www.diyaudio.com/forums/showt...618#post900618
-David
Copyright 1999-2017 diyAudio
