debuging aleph x debuging aleph x - Page 3 - diyAudio
debuging aleph x
debuging aleph x
Old 9th May 2006, 06:59 AM   #21
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
loic,
I copied my reasoning from another thread re. the DC offset.
Out to ground is not that critical. Anything between -1 and +1V is fine. DC between OUT- and OUT+ is what the speakers see so try to match for less then 100mV to start with. Less is better.
Looks like you have about 4mV (0.022 - 0.018) between outputs.
This is perfect.
The AC voltages can only be measured when a signal is applied to the input. You will need a steady sinewave. Either comming from a generator or you could burn something on CD. There is a current thread about generating sine waves here.
/Hugo
Old 9th May 2006, 08:46 PM   #22
veritelo is offline veritelo  France
hugo
Do i need an input cap anyway or not?
I burnt one CD with 60 hz sinewave and played it on my CD player linked to the amp and speakers connected.
I can hear the signal but still measure 0 Vac across R42/43 and R5 for example...
What is the problem? or what does it means ?
My multimeter is set on Vac measure
Loic
Old 9th May 2006, 08:55 PM   #23
Netlist's Avatar
Loic,
I can't say you need it, as your DC is nicely low and the purpose of the cap is only to prevent incoming DC be presented at the output. If it makes you feel better, add it. At the expense of a small tradeoff in sound.
The AC that can't be measured is a mystery to me at the moment.
Can you measure it across R6?
/Hugo
Old 5th June 2006, 09:01 PM   #24
Default aleph x debuging
I finally borrowed an oscillo to a colleague.
I found the problem with ac level. I was using the variable output of my cd player to the lowest output level meaning lowest AC voltage across resistors.
I then increased output level of my cd player output. I was then able to mesure AC voltage across resistors !!!!
thnks for your help.
loic
Old 5th June 2006, 09:08 PM   #25
Netlist's Avatar
Nice, enjoy the music before you start fine tuning.
/Hugo
debuging aleph xHide this!Advertise here!
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 24 14th May 2017 11:03 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 02:15 AM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Copyright ©1999-2017 diyAudio
