Old 21st April 2006, 12:46 PM   #1
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Zen v9 questions from a solid state newbie
Around 2,2A? That is what the lightbulbs had to endure in the V8 I believe.
From the V9 paper I gather it is around 2A. Is this fairly constant? Or does this change with transients?
Old 21st April 2006, 12:55 PM   #2
How "bad" is it if a b+ of 40vdc is used instead of 50vdc?
PS...bad in my book is if resistor changes have to be calculated
Old 21st April 2006, 01:29 PM   #3
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
2A is the DC operating bias current and doesn't not change with the AC signal. With the Zv9 sporting an Aleph current source at about 50% AC current gain it gets a boost and the signal current can peak to 4A during transients. This prevents clipping beyond the bias current.
At 40V rail you lose about 5V of peak voltage.
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
Old 21st April 2006, 01:56 PM   #4
Thanks Blues!!!!!
NEWBIE question SET vs. Solid State awhite1159 Tubes / Valves 42 21st September 2007 10:45 AM
My first solid state amp AAK Solid State 48 10th September 2005 06:38 PM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 05:26 PM
Page generated in 0.06565 seconds (73.28% PHP - 26.72% MySQL) with 10 queries
