If I would like to have tow outputs from an Aleph P 1.7, do i just put them in paralell, or?
For an example lets say I would like to drive to Aleph 2 per channel. BR /loovet |
#2 |
Hi.
If the output impedance is low enough and the 1.7 can provide enough current it shouldnt be a problem to drive 2 amps in paralell. In many cases thats the way it is done when commercial preamps have multiple pre outs. However given the simple design of the 1.7 i would consider plugin into 2 more channels with common innput terminals (impedance matching as needed) Then you will be sure to have the "real" 1.7 performance in all channels. And besides you would have a kick *** 4 channel surround preamp Best regards |
#3 | |
Account Disabled
In my opinion, just paralleling the output of P1.7 will work fine with no problem. Regards |
#4 | |
I would like to have two outputs per channel? In total four outputs... And for an example I would like to drive two Aleph 2 per channel, in total four amps... BR /loovet |
#5 |
Account Disabled
Aah . . . four Aleph 2s . . .
If one Aleph 2 has 10K-20K input impedance, it means that 800R output impedance of P1.7 (per channel) should see 2.5K-5K input impedance of two Aleph 2s (per channel). I estimate that P1.7 could still do the job. Regards |
| Aleph-X with JFET outputs | kiwi_abroad | Pass Labs | 6 | 18th March 2011 07:02 AM |
| Balanced outputs used as inverting & Non-inverting preamplier outputs | gni | Solid State | 4 | 19th September 2008 03:25 AM |
| 8V on outputs | dome406 | Chip Amps | 3 | 11th September 2005 03:16 PM |
| Bi-amp with Aleph P bal. and unbal. outputs | Sony | Pass Labs | 3 | 21st December 2004 07:09 PM |
| how low is 'low DC' on SOZ outputs? | psarin | Pass Labs | 8 | 8th March 2002 01:39 PM |
| Page generated in 0.07649 seconds (77.41% PHP - 22.59% MySQL) with 10 queries |
