Old 12th April 2006, 04:48 PM   #1
DarkOne is offline DarkOne  Slovakia
DarkOne's Avatar
Default XAB Measurements
Hi All,
This is an update to my previous thread about my amplifier. Description can be found in this thread
Measurements were taken with sound card ESI Juli@.
Feel free to comment.
I forgot to mention that I named amplifier XAB because it runs in heavily biased class AB and uses Pass' X patent.
So, I'll start with spectrum of 1kHz sinewave to 10ohm (couldn't find other power resistor at home) at 5W
Old 12th April 2006, 04:49 PM   #2
DarkOne's Avatar
1kHz 35W
Old 12th April 2006, 04:51 PM   #3
DarkOne's Avatar
1kHz square wave to 10ohm parael with 1uF capacitor at 25W
Old 12th April 2006, 04:52 PM   #4
DarkOne's Avatar
10kHz square wave at 25W to 10ohm and 1uF parael
Please note that also output from sound card is not perfect, but I hope this is enoug.
Old 12th April 2006, 06:00 PM   #5
The one and only
Nelson Pass's Avatar
That's really excellent.
Old 13th April 2006, 05:07 AM   #6
DarkOne's Avatar
Thanks a lot
Old 13th April 2006, 07:26 PM   #7
flg is offline flg  United States
flg's Avatar
Yes, Congrats. I remember the original post and the amp. I have the pics in my "Class A" folder. I liked this design. I remember N.P. made a good comment or two back then also. Happy to here it's working out well for you. Keep it up!
Old 14th April 2006, 08:58 AM   #8
DarkOne's Avatar
Thanks flg
I have few modifications prepared for the final version (amp is still in prototype stage). So I hope the amp will be even better.
1st - I'll try to cascode input diff. transistors. According to simulations, it can reduce higher order THD components. Also PSRR should be better. If not, I can eliminate it from PCB without much modifications.
2nd - These measurements were taken from amplifier, which did not use degeneration resistors on sources of diff pairs. I'm going to use 47R. If there's no success, I can bypass them anytime.
3rd - Currently every chanel is on 3 PCBs wired together with ribbon cable (practical, but not reliable). One chanel already damaged due to wrong connection. So new version (final one, I hope) will be on 1 PCB to avoid problems.
I'll post complete schematics with component values and PCB layout in few months, stay tuned.
Old 14th April 2006, 07:03 PM   #9
flg's Avatar
Yes, I tend to have a few proto boards to many by the time something works good...
Earlier you commented on your measurement set, ESI Juli@ sound card ??? Could you elaborate. I have some equipment but I just rcently downloaded some software (RTA & RMAA) for use on my E-MU card. I was initially impressed. But I deceided I needed to vacuum the floor before crawling around doing the cable thing. Well, I must have bumped the putor with the vacuum because I lost a chunk of the OS on disc and had to rebuild the putor with a few new components...
Yes, The Amp, another alternative to more components might be to raise the voltage as high as possible. Basically, the curve gets bigger but the swing stays the same and is little more linear. Just an idea.
If you run a BOSOZ at + & - 100V it works even better!
Old 14th April 2006, 08:56 PM   #10
PMA is offline PMA  Europe
PMA's Avatar
DarkOne,
do you really find it excellent?
Pavel
hi vi measurements blue934 Multi-Way 20 23rd August 2009 05:21 PM
New T-Amp measurements Pano Class D 12 14th March 2006 11:32 AM
SW measurements Grandma´s_SUB Everything Else 9 10th January 2005 01:34 PM
anyone have measurements of TB 871? morbo Multi-Way 5 27th November 2004 03:10 AM
Some CCS measurements Jocko Homo Solid State 10 29th May 2002 12:54 PM
Copyright ©1999-2013 diyAudio
