I am building a amplifier:
Unity gain 15W class A symetrical triple emitter follower output stage. For voltage gain my first thoughts were a tube circuit, but now I have thought at the possiblity for at mos-fet og j-fet driver/gain stage. This would be something like a zen with output buffer and according to Nelson Pass' definitions a single stage amplifier Is a bride of zen able of a +/-15-20V voltage sving without too much distorsion? Or should I look for at scaled down zen? Perhaps the new zen-9? EDIT: There will be ac-coupling between driver and buffer stage and no NFB! |
#2 |
The one and only
It is arguable that a triple darlington is three stages, each
amplifying the current and driving the next stage. If the technical community wants to call a darlington a single-stage, then I have lots more single-stage amplifiers than I thought. |
#3 |
But just think, you could have a half-stage amplifier.
Looks like Sponge Bob has killed another thread. |
#4 |
From Some years i have realized a single stage power amplifier that can deliver 50 watt/8 ohm or more. This stage have voltage gain so allows to drive it with with a cd player also (however low impedance is necessary). It acceipt balanced and unbalanced inputs and can switch from single ended to push-pull operation.
Also it permit class A or A/B operation of course. No capacitors in signal wire, no FB. I have tried to buy SIT transistors (especially the Tokin TKS45F323/322/320, TKS15R52, TKS17R52, 2SK180 for the best performance, but as we know it is very difficult. Now, thanks this forum i am in listing to buy the Lovoltech JFet and then to try with its. (my scheme is patent pending). I search a collaboration to engineering this product also for commercial use. There is one? Francesco |
#5 |
The one and only
I think you could make a middle-class income from such a thing.
#6 |
Hi Mr. Pass.
At this time i have built 3 different power version of this amplifier: 8 W, 30 W, 50 W. I have compared it with tubes amplifiers as: leak TL 10 Point one (upgraded version) Audio Tekne IT 2 DY-2 stages S-E amp (first stage 6463, output AD1 plus input (30k:50k) and interstage (30k:30k) transformes. Out tranny (all are made by Bartolucci) is 5k:16. First stage bias grid is obtained from battery. HV power from CLC filter and tube rectifier (Telefunken 1064 mesh). All filaments are in DC. Next days i will replace the 6463 with 6H30. I also have compared my amp with solid states as: Audio labor 8000 Classe Audio DR3 VHC (50 W class A) Accuphase A50 V (50 W class A) Spectral (i dont remember the model, perhaps DM 100) Phatos Twin Tower others. I will canned evaluate the weak point of my amp and then improved it. Now my last version sounds refined as near as the AD1 amp, tell me the friends, but it have other advantages such more dinamic, better bass etc Do you think that i must insist on this project and offer a commercial version of this amp? Can i make? (i dont have many money to spent) Tell me an advice. Best regards from Francesco. |
#7 |
The one and only
I can't advise you as to whether this is what you want to do
with your life. |
#8 | |
#9 | |
some people don't even consider that a follower is an amplifying stage (voltage or current follower, so a cascode (folded or not) would be a 1 stage) so, this amp would be a zero-stage amplifier
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
#10 |
Many people consider the cascode a single stage (so the SRPP and the MU-follower) because the devices are in series and the current is the same. However a triple followers must be consider as 3 stages. Francesco. |
| RMI-FC100, a single stage audio power amplifier | roender | Solid State | 1214 | 23rd January 2012 08:54 AM |
| single stage common-drain amplifier | Music_Sg | Solid State | 4 | 4th July 2006 06:45 PM |
| Anyone play with the Zen Single-Stage Single-Ended Class A? | Rino odorico | Pass Labs | 13 | 29th August 2002 10:01 AM |
| Page generated in 0.10666 seconds (80.85% PHP - 19.15% MySQL) with 11 queries |
