Old 18th November 2002, 10:33 AM   #1
rwagter's Avatar
Default Optimum placement of inductors in CLC filter
I'm in the process of building the aleph5 and just read that placing inductors next to each other is not a very good idea because they influence each others magnetic field .
Since I want to use a CLC filtered PSU on a reasonable footprint how can I do this.
My PSU looks like this:
cccLccc +
cccLccc -
where c=10.000uF and L=3mH
For 2 channels this means I have 4 aircore inductors (not very small anymore). Is there an other way perhaps CRC (ossilation???) or C-NTC-C (like xa-200) which is more space efficient.
Ralph
Old 18th November 2002, 12:21 PM   #2
rwagter's Avatar
This is what I mean
Is this frequency wise a problem??
Old 18th November 2002, 03:47 PM   #3
diyAudio Moderator Emeritus
roddyama's Avatar
Hi Ralph,
It shouldn’t be a problem. After the first set of caps, your ripple currents will be relatively low anyway. But if you’re still worried about mutual inductance, place the coil axis 90 degrees to the adjacent coil. This will minimize the mutual coupling.
Frequency is not an issue here. You're dealing with noise and 120Hz (100Hz) ripple.
BTW, your 3D rendering looks pretty nice.
Rodd Yamashita
Old 18th November 2002, 08:41 PM   #4
I agree.
Very nice indeed!
Sincerely,
Cambe
Old 18th November 2002, 09:59 PM   #5
The one and only
Nelson Pass's Avatar
Yeah, just keep the front end on the other side of the amp.
Caps/Inductors for a Filter hammdawg Parts 2 13th November 2007 06:51 PM
HF filter inductors for signal path cathode_leak Tubes / Valves 3 12th May 2005 09:32 AM
Looking for Inductors for use in Pi filter vsr123 Swap Meet 0 16th April 2003 12:43 AM
Hammond 159ZL as inductors in a Pi-filter? mats73 Pass Labs 7 8th April 2003 06:30 AM
pi filter in class a amp: okay to parallel inductors? jwb Solid State 6 20th October 2002 07:56 PM
Page generated in 0.09210 seconds (76.34% PHP - 23.66% MySQL) with 11 queries
