Zen V9 J-fet poweramp finished.
Old 8th April 2006, 09:00 PM   #1
steenoe is offline steenoe  Denmark
steenoe's Avatar
Default Zen V9 J-fet poweramp finished.
I finished the Zen V9 yesterday. Initial listening sessions, sounds really promising. I think this is the best sounding Zen amp, I have heard yet I used the PDDA boards, thanks for sharing the layout Peter Daniel and Veteran. Everything went smooth, both channels worked right away. I will note also that the grounding scheme on that layout is just right. There isnt any trace of hum or any other nasty things. Here is a picture of the internals, while adjusting the first channel. The trafos are 2 pcs of 300VA 2x18 volts followed by 2 DIY rectifierboards using 30A Stealth diodes, snuppered with small Rifa's. Smoothing caps are 4x 15.000uF Rifa's. The amplifierboards are like Veterans schematic. I wanted the amp to have the F-amp look, hence the horisontal fins. I am very pleased with the sound of this amp. The top-end is really smooth, detailed and "airy", better than I have heard before from a Zenamp. Thanks Nelson, for giving us this fine circuit
Steen
Old 8th April 2006, 09:01 PM   #2
steenoe's Avatar
Closeup of the board:
Old 8th April 2006, 09:02 PM   #3
steenoe's Avatar
The finished chassis:
The alu surfaces are etched by a NAOH solution.
Old 8th April 2006, 09:05 PM   #4
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Congratulations! That is one great looking build...
If you can see the speaker cone move...it's not hifi.
Old 8th April 2006, 09:07 PM   #5
steenoe's Avatar
Last one, from the rearend:
BTW, amazing that such a simple circuit sounds so good
Steen
Old 8th April 2006, 09:20 PM   #6
steenoe's Avatar
Congratulations!
Thanks Bas I am looking forward to hear some of you guys oppinion about this amp, too. I was pretty surprised to realise how good it sounds, even though I expected it to be good, from NP's writings
Here is a closeup of the way the J-fets are mounted with the legs extended with solid 1mm copper wire.
Steen
Old 8th April 2006, 09:23 PM   #7
gl is offline gl  United States
Hi Steen,
A beautiful amplifier. Very professional looking indeed. The brass feet are nice touch too!
Graeme
Old 8th April 2006, 09:49 PM   #8
apassgear is offline apassgear  Mexico
apassgear's Avatar
Really neat Steen, that case shines as good as a First Watt.
An best of all it sounds as it should, best of Zens?
There seem to be other contenders for the title though, Carpenter’s ZV7T. Maybe John will make a ZV9 and report his findings.
Congratulations!!!!
Old 8th April 2006, 09:49 PM   #9
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
veeeeeeeeeeeeeeeeeerrrrrrrrrrrrrrrrrrrrrrrrrrrrry ugggggggggggly!!!!!!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 8th April 2006, 10:25 PM   #10
moe29 is online now moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
it's so nice to see an amp completely finished
looks great
Zen V9 J-fet poweramp finished.Hide this!Advertise here!
YAP - Yet Another PowerAmp syn08 Solid State 315 5th October 2011 12:39 AM
Copyright ©1999-2017 diyAudio
