#11 |
Dennis Hui, what is the manufacturer of your transformer ???? Plitron ???
Because I have to change my transformer on my Aleph30.. Thank you |
#12 | |
it from a retail store. Dennis |
#13 | |
Brian, I bought an Antek 39-0-39V transformer (700VA). I used a variac to help check secondaries and the power supply, however, at roughly 40-50% of full mains voltage the variac starts to buzz (before connecting to PSU). I am a bit apprehensive about going any further. What would cause the variac to make noise? SteveA |
#14 |
Not sure. My guess would be phase variance. Did you try just powering up the trafo with nothing connected to it's secondaries?
Twisted Pear Audio |
#15 | |
That's what I did. I was just monitoring the voltage at the secondaries (so I could "pair up" the correct secondaries). I just finished an Aleph 4 (actually a pair of A4 mono's) and the variac made a similar "noise" as I powered up. I was able to go to full mains voltage, but this time the variac seems to have increased it noise level. Steve |
#16 |
I menat just powering uop the unconnected trafo without the variac in the equation.
#17 | |
Nope, haven't done that yet. I'll check it out tonight. Steve |
#18 |
For an Aleph30 you need 25vdc PSU. You would need 21 to 22VAC secondaries. I'm using a torid with 45VAC secondaries using the 230VAC primaries for 120VAC to get 22.5vac for secondary. I''m getting 24.99VDC PSU out using a CRC circuit.
Here's a picture of my Aleph30 trafo and PSU. My 1st Aleph Amp Good luck, -David |
#19 | |
Hi David, I saw your thread, I think I may have the same heatsinks. I figure I'll get ~23-24V rails with this (Antek) transformer. I saw some Antek's on Ebay (400VA 22-0-22 if I remember correctly). A pair of those might do well but first I'll see how this one works. Steve |
#20 |
Hi Steve,
Attached is a pic of the PSU simulation I used, and it turned out to be very accurate. I used a small amount of resistance to achieve the Aleph30 spec of 25VDC with 22.5VAC trafo secondaries. I actually had 24.99VDC using the mini-aleph PSU boards and parts from the GB with 4 3 watt resisters per side. -David |
| power transformer recommendation | nukaidee | Tubes / Valves | 31 | 13th December 2008 03:34 AM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| transformer selection recommendation for aleph 30 | hc167 | Pass Labs | 12 | 27th March 2007 04:33 AM |
| Aikido Transformer recommendation | Original Burnedfingers | Tubes / Valves | 0 | 14th March 2007 10:51 AM |
| transformer voltage needed for Aleph 4 or Aleph 2 | diy student | Pass Labs | 23 | 28th November 2001 07:54 PM |
