Old 7th April 2006, 03:41 AM   #1
ccvogel is offline ccvogel  United States
Default 16 Ohm speakers with Pass Aleph 3/30?
I am building a two-way loudspeaker system with an active crossover; hence, the drivers will be directly coupled to the amp. The drivers are both 16-Ohm. Can an Aleph 3 and/or an Aleph 30 handle a 16-Ohm load? What are the consequences relative to the more conventional 8-Ohm load?
Thanks for your help,
ccvogel
Old 7th April 2006, 04:21 AM   #2
mpmarino's Avatar
My first thoughts are:
1) an obvious ~50% reduction in power.
2) The option to bias it lower/ = less heat
3) The option to use less output devices (??)
I'm thinking maybe an aleph 5 biased down and with less output devices may be better??(in other words, a higher voltage a30 with low bias??) Please note the question marks, others will most likely have a better answer.
regards
Crazy Yankee.
Pass 350.5 vs aleph daly41k Pass Labs 8 19th March 2007 03:19 PM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 03:10 PM
pass aleph P VS pass X2 first version perusicchio Pass Labs 10 5th March 2004 10:06 AM
Pre-Amp Pass Aleph L Laketown Pass Labs 5 18th September 2003 10:10 PM
Page generated in 0.06206 seconds (69.41% PHP - 30.59% MySQL) with 10 queries
