Pass Son of Zen w/current sources (etc.) - Page 7 - diyAudio
Old 1st November 2003, 02:00 AM   #61
The one and only
Nelson Pass's Avatar
Originally posted by GRollins
Being two stages, it probably doesn't count as a true Zen amplifier any more, but speakers don't care.
As I recall from the original article, the Zen effort is an exploration
in simplicity, and I don't see why this wouldn't qualify.
Old 1st November 2003, 02:01 AM   #62
Look at this, it's 1 pcb. You may stack, for example, 5 units, on 1 heat sink. Parallel everything except for the speaker outs. Then, calibrate the 4 pots so that all the units match. Finally, bridge the speaker outputs & voila...
Non-VGS matched mosfets now matched.
_______
Brian
Old 1st November 2003, 02:29 AM   #63
Bricolo is offline Bricolo  France
Bricolo's Avatar
And if we compare Grey's output stage+bosoz with a zen+bosoz, we still have the same "keep it simple" idea
Old 1st November 2003, 01:46 PM   #64
audioPT is offline audioPT  Portugal
Originally posted by Brian Guralnick
Instead of trying to steal this thread, just post the question as a new topic, & if Mr Nelson feels up to it, I'm sure he'll add photos.
No one here is stealing threads
Old 1st November 2003, 05:00 PM   #65
The one and only
How much matching do you want? It's pretty easy to get
10 mV. we do it all day long. My standard max for output
DC is 100 mV, although some might say that's too much, only
rarely is it a real issue.
Old 1st November 2003, 06:17 PM   #66
jan.didden's Avatar
Brian,
I can follow your reasoning, but this is a very dangerous course of action. Even for a single, having 3 or 4 pots in an amp with all the drifting and aging is asking for problems. And parallelling 4 or 5 means that as soon as you close the lid after adjusting, they will start to drift apart, and one or the other will load down the rest, and it'll be a real mess.
Generally, it is considered a sign of competent design when no adjustments are needed, while still using unselected standard components. YMMV.
Jan Didden
Old 1st November 2003, 06:20 PM   #67
100mv with many designs is not an issue. It's also easy to achieve when dealing with more than 10 mosfets. My illustrated circuit with the 20 turn precision pots allows you to adjust many modules, say 4 for example, down to 10mv, of less. Now, paralleling these modules without output series resistors for the speaker drive should allow for a balanced load across all the 8-10 mosfets a DIYer may have purchased.
Example PCB... (Another VIA-LESS design)
_______
Brian
Old 1st November 2003, 06:26 PM   #68
When stacking this PCB vertically, you just need to feed 12aug solid core wires through CN1 & CN3, 18aug for CN5. On the top PCB, put in standard terminals for CN2 & CN4 & CN6.
RP3 & RP4 calibrates the CCS for Q3&4, TP1 & TP2 is there to measure the emitter resistor voltage.
RP1 & RP2 calibrates the output offset of mosfet Q1 & Q2.
_______
Brian
Old 2nd November 2003, 04:06 AM   #69
Originally posted by janneman
Brian,
Jan Didden
That's why I built this device:
http://www.diyaudio.com/forums/showt...957#post257957
_______
Brian
Old 3rd November 2003, 04:07 PM   #70
Brian,
Jan Didden
Ok, got rid of the pots.
For the mosfet offset voltage, I'll just match the mosfets.
For the CCS side, I added an NPN transistor across (1 side example) Q3's emitter, base & V-15. Now, when the voltage across R9 is large enough, the base of Q3 will be pulled down creating a further regulated CCS.
_______
Brian
constant current sources... cathode_leak Tubes / Valves 10 29th March 2005 10:18 PM
Current Sources vinay Pass Labs 1 19th March 2005 04:23 AM
Op Amp based current sources Kevinbd Solid State 1 3rd October 2004 07:18 AM
Aleph P current sources? stefan Pass Labs 12 20th August 2002 08:01 AM
Current sources (not sinks) dlharmon Pass Labs 1 6th February 2002 10:36 PM
Copyright 1999-2017 diyAudio
