Pass Son of Zen w/current sources (etc.)
Old 29th October 2003, 08:18 PM   #41
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Originally posted by GRollins
Grumble, grumble, grumble...
Grey
Grey, are you sure...well probably you are...but just in case, was your file smaller than 800x600?
/Hugo - eagerly waiting for the .jpg
Old 29th October 2003, 08:34 PM   #42
Bricolo is offline Bricolo  France
Bricolo's Avatar
Grey, maybe the graphic files are limited in size AND resolution
but there's nothing said about it
Old 29th October 2003, 09:45 PM   #43
vic2 is offline vic2  United States
I understand the issue of Peletiers moving heat from one surface to another. But, does the hot surface need to be cooled? Does the heat removed from the source and that generated by the Peletier device need to be dissapated or does the Peletier device sustain a temperature differential between the two sides? Or, even if it does sustain a temperature differential, is the temperature difference simply brought up to a higher level? Hypothetically speaking, say 5 C one side and 30 C the other and then when the cold surface is brought up against the hot surface does it become something like 25 C one side and 50 C the other.
I have noticed that Peletie devices are often sold with cooling fans. I considered this for a while then I got hooked on the GC thing and haven't considered it much since.
Vic
Old 29th October 2003, 11:09 PM   #44
Bricolo's Avatar
A peltier is simply a "heat pump"
It literally takes the heat from the component on it's cold surface, and sends it to the hot surface
you absolutely need to cool the hot surface!!! Use it uncooled for half a minute, you'll be surprised. It will heat so much that the powering wires will unsolder them (that hapened on one I had. If it's normal, or if it was bad soldered, I don't know)
Peltiers aren't meant to be used there. You'll have to dissipate even more heat (the transistor's one + the peltier's one)
Peltiers are used for cooling components below the ambiant temperature, something you can't do with classical air cooling. But they require more air cooling on the peltier that without it
If you have difficulties to cool your transistors, adding a peltier will give you even more difficulties
Old 29th October 2003, 11:24 PM   #45
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Grey, could you please email the graphic to the webmaster email address and I'll try to work out what is going on ... this is the 2nd report I've had but try as I might, I've been unable to replicate the problem.
- Dan
Old 30th October 2003, 12:22 AM   #46
Bricolo,
That's what i figured. It makes sense.
Vic
Old 31st October 2003, 01:34 AM   #47
GRollins is offline GRollins  United States
Default The Follower of Zen
Okay, let's try this again...
Just something to kinda stimulate discussion.
Old 31st October 2003, 02:41 AM   #48
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
this follower is going to need to hear a sermon
Old 31st October 2003, 02:54 AM   #49
It's for those who were upset over the high parts count in the Son of Zen. (Ahem...)
As a fringe benefit, the damping factor is higher and the heat dissipation lower. Distortion will also be somewhat lower, in that followers have 100% local degenerative feedback.
The caveat is that, being a follower, it will require a fair amount of gain from stages upstream, whether they be preamps, active crossovers, or whatever. Like the original SOZ, it will be happiest with a balanced input.
Naturally, you can replace the 8 ohm resistors under the MOSFETs with current sources, which will make things even more efficient, but that's another post for another day.
Grey
Old 31st October 2003, 03:24 AM   #50
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Well, that must be close to a record for simplicity....
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Pass Son of Zen w/current sources (etc.)Hide this!Advertise here!
constant current sources... cathode_leak Tubes / Valves 10 29th March 2005 11:18 PM
Current Sources vinay Pass Labs 1 19th March 2005 05:23 AM
Op Amp based current sources Kevinbd Solid State 1 3rd October 2004 08:18 AM
Aleph P current sources? stefan Pass Labs 12 20th August 2002 09:01 AM
Current sources (not sinks) dlharmon Pass Labs 1 6th February 2002 11:36 PM
Copyright ©1999-2017 diyAudio
