Pass Labs D1
Pass Labs D1
Old 20th March 2007, 05:33 PM   #31
Valeriano is offline Valeriano  Italy
me too
thanks!
ciao
.vale.
Old 20th March 2007, 09:43 PM   #32
bou is offline bou  Canada
I would also like to have it.
hibou23 (at) gmail (dot) com
Thank you
Bou
Old 19th April 2007, 10:17 AM   #33
t. is offline t.  United Kingdom
t.'s Avatar
I would like it too please multibit (at) ntlworld (dot) com
Thank you!
Can the D1 be used with a PCM1794 and be set to line out ?
The PCM1794 has +/- outputs
Old 19th April 2007, 01:46 PM   #34
cviller is offline cviller  Canada
cviller's Avatar
As far as I recall, pcm1794 has twice the output current needed, so you'll have to scale down the gain in order to avoid clipping. But it should be easily done.
Old 19th April 2007, 03:51 PM   #35
tjdd is offline tjdd  Taiwan
Please send me a copy too. Thanks
lai.mu57@msa.hinet.net
Old 19th April 2007, 04:01 PM   #36
t.'s Avatar
Thanks Cviller I've been searching around trying to find some info how to use it with a dac that has +/- outputs , if I had a balanced pre etc I'd just build a pair of D1's, balanced in balanced out but I need line out.
I presume theres some instructions in the manual how to connect it up to various dacs?
Old 19th April 2007, 04:29 PM   #37
cviller's Avatar
You won't find much instruction in the manual, but d1 is balanced anyways. You make 4 identical iv stages and use two for each channel. I have single ended preamp, so I just take the signal between + and gnd on the output of the iv stages. A bit of a waste really, but I'm planning on building another preamp to match my F4...
Old 19th April 2007, 04:34 PM   #38
t.'s Avatar
Ok thanks, I was hoping to be able to use just a pair of the D1's mainly to keep things compact with the PCM1794 dac, oh well
Old 4th June 2007, 07:15 AM   #39
matejS is offline matejS  Slovenia
could you please mail me D1 service manual as well... to mattityahu (a_t_) gmail (_d_ot) com
Thank you,
Matej
Old 4th June 2007, 07:35 AM   #40
Manu is offline Manu  Europe
Manu's Avatar
Hi cviller,
Did you build the D1?
manuel
Pass Labs D1Hide this!Advertise here!
FS: Pass Labs X-250 jtwrace Swap Meet 0 17th June 2007 03:20 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
