I've got the power supply capacity, and the heatsinking...can I safely double the bias in an Aleph 30.
I figure .75 amps are going through each Mosfet now...so I guess with a doubling of BIAS there would be 1.5 amps going through each mosfet...
Would I double the BIAS by halfing the resistance of each source resistor? (total of twelve)
Thanx in advance
Thanx in advance
Banned
Joined 2002
audionut said:I've got the power supply capacity, and the heatsinking...can I safely double the bias in an Aleph 30.
Thanx in advance
Why do you want to do this ?
Why do I want to double the BIAS??
I noticed when driving low impedences of 1 ohm or so, the amp can only swing about 10 volts before clipping, (if memory serves)...At 8 Ohms, the amp can swing 20 volts or so....
If I double the BIAS...the amp will be able to swing more volts before clipping....
In my DIY readings...I am under the impression that the more BIAS the sweeter the amp...
I also notice that if I parrallel the channels, the amp will swing more volts into low impedences.
yes halving the source resistors would aprox. double the bias.
1.5A times 25V = 37,5 watt per fet wich is quite high but still ok if your heatsinks are big enough.
Be shure that the mica / kapton isolators are good enough and measure the fet temperature at the case (below 80°C would be nice).
10V at 1 ohm is quite high, probably more like 5V or lower. Even with 4,5A bias and 50% ac-current-gain peak current is "only" 9A
and peak voltage only 9V into one ohm
I´m shure the amp will sound better this way if the rest is up to it.
William
William
Although I have never 'doubled' the bias, experience leads me to agree that this will almost certainly be true
wufffaff, wouldn't the halving of source resistors require halving of the speaker resistors to keep ac gain the same?
wuffwaff said:mpmarino,
yes ac-current-gain must be reset but this could also be done with R19 (wich connects the current source to the output).
William
Yes..yes.. You must be tired of saying that
- double the BIAS in an Aleph 30
