hi
supply = +-25 irfp140n +irf9610 +mpsa18 my new aleph 3 is under test all dc voltage are ok just change 2 things: 1-my aleph current source was unstable but with 1nF on mpsa18 base and collector it s rock stable now 2-my bias was 1.7A change R113 for 47.5k + 30k and now my bias is 2.1A cold and 2.05A hot first good news :-) - very good 200khz @ -3db maybe because my input stage is 25ma not 20ma ccs - 10khz square wave test is good just a very small overshoot bad news :-( I m lost to check aleph current modulation -test no 1 : ------------------------- F=1khz Vout=45v peak to peak load = 8ohm power resistor my scope is on one .47ohm (upper aleph source resistor) with vout=0 volt on .47 = .5v with vout=45vpp the voltage swing between .05v and .92v .92 / .47 = 1.95A x 2 for aleph 3 =3.91A peak is it normal or normal is 3A or 3.5A or ??? -test no 2: -------------------------- F=1khz Vout=45vpp scope on AC position 650mVPP on rout .1175 (4 x .47) 870mVPP on one upper aleph .47 source resistor 450mVPP on one lower irfp140 .47 source resistor but no idea what to do for check my 50% modulation with these voltages thanks |
#2 |
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
hi choky
I give you the table or alpeh make your choice :-) your url post is speaking remove some resistor to test but must be possible without remove. please confirm : aleph 3 bias=2A max peak current on .47 with 45vpp is ?? thanks |
#4 |
hehe- I think that both-the table and aleph are perfect where they are ...
in any case- seems that English is not native language for both of us,so it's maybe easier to quote Master of Latheral Thinking And Vertical Mistfets : " you generally want to set the gain so that the AC variation of the current source is about 1/2 the output current. It can be more or less, but 50% gives the optimal energy efficiency figure. You will note in the Aleph schematics that the Base of the NPN transistor which controls the current source attaches to the output of the amplifier through an RC network. The value for C is set arbitrarily high so that it does not interfere with audio frequencies, and it is the value of R which is the most convenient spot to adjust the gain of the current source. For the purpose of this discussion, I'll call it R0. If you set the amplifier driving a sine wave into a load (let's say 16 Vrms into 8 ohms at 100 Hz), you can measure the current variation of the gain N channel Mosfets (whose Sources attach through power resistors to the - supply rail) with a cheap AC voltmeter placed across one of these Source resistors. With R0 taken out of the circuit, you will get one AC value across the Source resistor (say 470 mV, for example). As you put a value for R0 in the circuit, this will decline, and when it measures 1/2 the value without R0, you have reached 50%. If it measures 1/4 the value, the current gain of the Aleph source is 75%, and this figure is too high for a standard Aleph. Most listeners like the Alephs at 50% or lower, so I recommend between 50% and 100% of the AC voltage value compared with no R0" if you read that slowly ,you'll realize that sayed R0 is nothing else than that little resistor in series with 220UF-going from output rail;if we look at same pdf -that's R114 =750 ohms trust me-or trust Master - lifting one leg of sayed resistor in measuring purpose is easiest way for testing current gain of Aleph CCS....besides-that resistor is exactly one you need to decrease or increase for adjusting sayed current gain from top of my head- sum of upper 0,47 resistors AC current modulation must be exactly half of AC current modulation through output 0,47 resistors....but-you must know that I do my typing on the end of pretty long day........my brain is not exactly capable for simple equitations in this moment
#5 |
650mVPP on rout .1175 (4 x .47)====(0,65/0,47)x4=5,53A
870mVPP on one upper aleph .47 source resistor====(0,87/0,47)x2=3,7A 450mVPP on one lower irfp140 .47 source resistor===(0,45/0,47)x2=1,9A seems that your goal is 5,5A/2 ~ 2,25A or less for CCS or-even easiest to say- same AC voltages at lower 0,47 and upper 0,47 resistors for start-increase that R114 to 1K and then measure again I must go to sleep..............
#6 |
ok no choice to remove 750ohm to do a good test
i will do next possible day and give you feedback thank you very much choky |
#7 |
hi choky i just finish the test and it s work great :-)
test no 1 for volt on lower .47 : R=750 F=1Khz Vout=10VPP without=300mVPP with=105mVPP ---> 105/300=35% ---> 65% AC gain Vout=20VPP without=600mVPP with=205mVPP ---->205/600=34.17% ----->65.8% AC gain I m surprise the AC gain is constant with variable Vout with 1Kohm test i fall right on 50% AC gain :-) after reading test no 2 for AC gain test without remove resistor but not sure check that choky: Ac gain ??=I upper .47 (x 2 for aleph 3) / I out I upper=(.87/.47) x 2=3.7A I out= .65/.1175=5.53A (.1175 = 4 x .47 ) 3.7/5.53=67% ~= 65% my next step will be to update my tube preamp to lower gain but do you have a opinion on tube preamp for aleph 3 and for you what is the best preamp , tube or boz or boboz or aleph P or ? thanks |
#8 | |
if that's case-you made it..... besides-this calcualtion looks OK to me: "I upper=(.87/.47) x 2=3.7A I out= .65/.1175=5.53A (.1175 = 4 x .47 ) 3.7/5.53=67% ~= 65%" but only as example preamp? I dunno really-somebody else must give you advice about that...I made just BOZ 'till now,and I have doubts that I'll made some other ,just because in preamps that's not my cup of tea...you can always look at my site what is my cup..... maybe one of this days I'll play a little with BOZ variation with some nice piece of iron in output-that's why I made it in first place BTW -which tube preamp you use?
#9 | |
why you are surprised? its basic premise of NP's patent of Aleph CCS...Constant DC current,but also constant AC current gain......
#10 |
if I undertand you corectly-with 1K as R114 you have on upper 0,47s exactly half of output current?
if that's case-you made it..... ------sorry my english is so so yes with 1kohm volt on lower .47 20vpp without=600mv and with=300mv 3.7/5.53=67% ~= 65%" but only as example just because your goal is 50%.... -------yes only for example BTW -which tube preamp you use? --------6SN7 supply=300v bias=5ma transistor ccs load +6AS7 supply=150v cathode follower for zout=100ohm but i need to remove the first 6SN7 because the gain is too high for aleph but the problem with my design is fc -3db is only 50 khz maybe a boz project for next winter :-) why you are surprised? ---------my first impression was very wrong something like current modulation 50% a full power 25% at half power thanks |
| Thanks Mr Pass for my Aleph 2 and UGS diy | Lau700 | Pass Labs | 19 | 1st August 2007 07:51 PM |
| Pass 350.5 vs aleph | daly41k | Pass Labs | 8 | 19th March 2007 03:19 PM |
| Pass Tharagard A75 vs Pass Aleph 1.2's | daly41k | Pass Labs | 7 | 18th February 2007 03:10 PM |
| A New Aleph 5 Is Born | SNOWCRAB | Pass Labs | 22 | 16th October 2004 01:29 PM |
| pass aleph P VS pass X2 first version | perusicchio | Pass Labs | 10 | 5th March 2004 10:06 AM |
| Page generated in 0.12851 seconds (90.44% PHP - 9.56% MySQL) with 11 queries |
