I have searched the forum for previous threads regrading this issue but I was unable to find one .Or maybe too unpacient
Anyone thinks that one might use Intel PIV Processor heatsinks for an Aleph 3 or 5 project ? I have a box full of them . Pentium IV boxed, originals Some have a flat bottom alu only with fins straight up and some have a cooper heart and then the fins are spreading circular All of them are equipped with fans - quiet ones very easy to work at 3 or 4 volts I thought first to use them as one for each MOSFET - with or without fans Or to place them and tight them together on an alluminium plate ? Stupid ?
#2 |
The one and only
I think they'll work fine, as long as the fans are quiet enough
for you. |
#3 |
Master
Tnx for your kind reply I was thinking to mount them tight on an allu plate and use them without fans Size of a cooler is about 10x7cm with 5 cm fins . Pretty aglomerated though For 4 coolers I have an 28x10x5cm radiator with a lot of fins But as far as i know too many fins together are not efficient unless you ventilate them Bottom line - because Intel or AMD sites are poor in info .Does anyone knows what is the (passive) thermal coefficient for such a heatsink. No fan involved |
#4 |
diyAudio Moderator Emeritus
Try it and do post the results. I'd love to see a picture of say twelve or sixteen fans cooling an Aleph.
![]() /Hugo |
#5 |
Here's a couple of threads on this forum concerning computer heatsinks:
Alpha Heatsinks http://www.diyaudio.com/forums/showt...?postid=320864 compact aleph5 with cpu heatsinks finished The search engine on this board is not as good as it should be. Google has a cool site search feature that I've found helpful: KEYWORDS site:www.diyaudio.com I used this criteria to find the above links, there are a lot more to explore. Cut and paste this text into the Google search box: computer heatsinks Aleph site:www.diyaudio.com Good luck, -David |
#6 | |
Hi!
I have an A5 and it is hot, a real power plant... :-) Greets: Tyimo |
#7 |
Indeed it's not enough.I made some calculations based on documentation found on conrad site
I quit the idea. Out of thread Thanks all ! |
#8 |
I have 2 "Tower 112" Heat Pipes by Thermaltake I think. They are made for P4 processors. I tested one at 100W with 2 TO-247 pkgs and the fan at a barely audible level(for me) and I believe it will do the trick. I did not get any temp measurements but I think the surface of the radiator portion was at about 60C... You have to consider, you have a die or a case thermally conductive contact area dumping 1/3-1/2 that 300-350W power supply. I would hope these things can dump 100W. And, at $20-100 they are a great deal compared to the Thermalloys and Conrads... It is difficult to use the lower profile units and still have a quite fan. The heat pipe like I have has alot of area, a 4"x4"x4" block of copper radiator. You can even get complete processor water cooling systems for those Monster amps and just use 2, 4 or 6 of the processor portion...
| FS: Heatsinks for Aleph(s).. | skaara | Swap Meet | 2 | 29th August 2006 10:36 AM |
| Computer heatsinks for audio | deleveld | Solid State | 7 | 1st December 2004 05:11 PM |
| Heatsinks - Aleph 5 | ElectroNick | Pass Labs | 7 | 13th December 2002 08:55 PM |
| New Aleph 4 - heatsinks anyone? | apassgear | Pass Labs | 43 | 10th December 2002 08:44 PM |
| Heatsinks for Aleph | skaara | Pass Labs | 8 | 16th September 2002 07:30 AM |
