Threshold NS10 Lineamp PCB
Old 18th November 2009, 06:05 PM   #581
Originally Posted by peranders View Post
Is this oscillation on every board or only under certain conditions?
it was in the version sent to Janneman for pre-production testing.
regards Andrew T.
Old 19th November 2009, 11:57 AM   #582
CeeVee is online now CeeVee  Portugal
CeeVee's Avatar
In my case i had a bit of a rat's nest so i cannot rule out the wiring.
Old 19th November 2009, 02:19 PM   #583
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
I'm still in the process of testing my version, but haven't seen any oscillation with very light loads. If anyone else would be willing to help, I think I have a few more board sets.
Old 12th December 2010, 06:18 PM   #584
PTSOUNDLAB is offline PTSOUNDLAB  France
PTSOUNDLAB's Avatar
Hello friends
I build an NS10 with apassgear schematic http://www.ptsoundlab.com/temp/ns10/ligne.jpg (thanks to him !!!) and with my PSU http://www.ptsoundlab.com/temp/ns10/alim.jpg
The sound is marvelous ! Very good details and dynamic, beautiful basses. A very pleasant preamplifier.
I tried to add to it a RIAA stage, I included original components in apassgear schematic (see in black) http://www.ptsoundlab.com/temp/ns10/riaa.jpg
At the same time, I added the head amp for MC http://www.ptsoundlab.com/temp/ns10/prepre.jpg
The result is very very good, no audible noise and a very good integrated preamplifier.
BUT, I have an issue. The line stage give a lot of basses and is perfect, but the RIAA stage don't give realy enough basses. It seems that the RIAA curve is respected but with basses behind.
Treble seems ok but the lack of basses give me the feeling that they are a little high.
Could someone have an idea of why ? what is the error in my schematic ? or how can I improve basses ?
Thanks a lot in advance if you can help me.
Cordially
Pascal
Old 12th December 2010, 08:13 PM   #585
arensattic is offline arensattic  Netherlands
arensattic's Avatar
Dear Pascal,
This reply refers to you noticeing a lack of bass in the sound produced by the NS10 RIAA stage. When I examined the schematic posted at your website (PT Soundlab), I noticed that your schematic has two series-connected 301k resistors shunting the RIAA network. This shunt results in a rather severe reduction of bass, as compared to the original RIAA curve. Removing the shunt may give you the bass which you are missing....
May be the shunt is a modification of the original NS10 circuit, in order to attenuate subsonic garbage from warped records. But I guess the action of the shunt is rather too severe. Perhaps the father (auctor intellectualis) of the NS10 circuit, Nelson Pass, may comment?
These are my five cents from The Netherlands (I have run some PSpice simulations which indicate that the statements I made above are correct).
Best regards,
Aren van Waarde (aka Arens Attic)
Real HiFi runs hot and has only one speaker unit per audio channel.
Old 12th December 2010, 08:23 PM   #586
PTSOUNDLAB's Avatar
Thank you very much Aren
I will try tomorrow and let you know the result.
Otherwise, without this issue with RIAA, this preamp is a killer, very nice sound with F5 amplifier.
I'm a fanatic of valve amplifiers and preamplifiers, and I don't love a lot solid state,... except Nelson jobs, I love all Nelson amplifiers and preamplifiers.
Cordially
Pascal
Old 13th December 2010, 06:37 PM   #587
PTSOUNDLAB's Avatar
Hello Aren
the issue is the same with or without 301K resistors, lack of bass
So now i see two possibilities
- false RIAA network
- bad capacitors in RIAA network
I will order new capacitors to verify. For the RIAA network, it is the one I saw in all schematics.....
http://www.ptsoundlab.com/temp/ns10/sl10-riaa.gif
http://www.ptsoundlab.com/temp/ns10/RK%20Ronningstad's%20version%20of%20the%20NS10.pdf
I tried with 18,2K like RK or 16,5K like original and it's the same
http://www.ptsoundlab.com/temp/ns10/sl10-sch.gif
...., so I think it is good ?
If I don't make mistake, RIAA Network is made by 16K5//4,7nF 301K//15nF
Thank you for your help
Cordially
Pascal
Old 18th February 2013, 08:54 PM   #588
Robert the cat is offline Robert the cat
Default NS-10 Preamp service manual / original schematics
Does anyone have a copy of the original NS-10 service manual, or at least the original schematic? Urgent! .... DIY AUDIO Member: "Robert the cat"
Old 18th February 2013, 10:10 PM   #589
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
buried in Pass forum
you'll find everything
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd August 2014, 06:15 AM   #590
VintageAmp is offline VintageAmp  United States
VintageAmp's Avatar
Default Need help with missing chip
No Service manual ever existed that I know of.
If any one with an NS 10 could look under the hood for me I would be grateful.
I need to know about a 14 pin DIP near the right front of main board. This early unit has a one piece gain circuit PCB. The 14 pin socket is next to a FT 317 w/ heat sink. What is the chip and the orientation? Any help mucho appreciated.
Vintage Amp
Threshold NS10 Lineamp PCBHide this!Advertise here!
My Take on Threshold NS10 Russ White Pass Labs 583 23rd May 2012 06:05 AM
Threshold NS10 renewed steenoe Pass Labs 54 31st May 2007 08:08 PM
Threshold NS10 ponger Pass Labs 4 12th November 2005 12:29 PM
