Old 25th March 2006, 04:41 PM   #1
routhun is offline routhun  United States
Default Help needed for Nakamichi TA-3A stasis receiver
Greetings to all,
Few days back I've picked up this receiver in non-working state. The receiver will not come out of protection mode. After some investigation I found that output of left channel stuck at -ve Vcc which is -54.3V. I've checked all the transistors in that channel, but did't found anything bad. I've tried to compare the voltages with working channel, but this is next to impossible as the PCB routing for one channel is completely different from another channel. Also the PCB routing is complex and it is not easy to trace back the schematic from the PCB. Can somebody help me in fixing this receiver? I will greatly appreciate if somebody can provide me the service manual or schematic of the power amplifier.
Thanks in advance,
Nageswara
routhun
Old 25th March 2006, 04:54 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Nageswara,
There is a power resistor that overheats commonly in these. It supplies the reference for the current sources (off the negative rail). Replace both with a higher wattage.
Now that is the common fault (wish I had the manual still to pin point it). There may be other faults as well.
-Chris
Old 25th March 2006, 05:21 PM   #3
Hi Chris,
Thanks for responding. It looks to me that there are couple of current sources in this amp, if you can hint me about which one, I can look at that one. Also the components are crammed and accessing them is very time consuming. If you remember the value of the resistor, please tell me this also helps alot.
Thanks,
Nageswara
routhun
Old 25th March 2006, 05:33 PM   #4
anatech's Avatar
Hi Nageswara,
Yeah, it's no fun working under the tuner PCB. I no longer have access to my service manuals or I'd give you all that information.
I think it was a 22K 1/2 W. Use a 1 watt metal oxide resistor to replace it with. There is one ccs per channel supplying the diff pair. That's the feed resistor.
-Chris
Old 26th March 2006, 03:34 AM   #5
Hi Chris,
Thanks a bunch!!! Hats off to your memory. The 22k resistor is indeed the problem. Once I replaced with 22K, 1W the amp worked like a charm. I've replaced the resistor in the other channel with 1Watt one. The receiver sounds great, it has punch and very good highs too. It has lot of detail some time it gives an impression that the highs were artificially boosted, and its sound is almost as sweet as my Luxman R-1120 receiver.
Thanks again,
Nageswara
routhun
Old 26th March 2006, 04:07 AM   #6
anatech's Avatar
Hi Nageswara,
The Luxman is yet another good sounding amp.
-Chris
Old 23rd March 2008, 07:31 AM   #7
jcro is offline jcro  United States
Originally posted by anatech
Hi Nageswara,
-Chris
Thanks, Chris from another TA-3A owner. Same problem. Same Solution.
I documented my repair (1/2 watt 22K Resistors R309L and R309R replaced with 2 watt equivalents) with a lot of photos. If anyone's interested, I'll be glad to post. I bought the service manual PDF online, so anybody, feel free to ask questions.
The TA-3A comes apart easily enough ... no tricky hidden screws or clips ... it was easy to pull the top boards to get at the main PCB ... easy to remove the bottom too.
I got my TA-3A free from our local Craigslist. A nice guy who wanted the receiver to end up with someone who appreciated it enough to repair it. It came with a CR-4a cassette deck too, although that has a bad left record channel ... my next project. The deck and receiver are linked with a DIN cable allowing control from one remote.
Having spent the last few hours enjoying the clean sound of the STASIS amp, I'm pretty pleased. In many respects it reminds me of my Yamaha RX-596 when operating in Pure Direct mode, although the midranges on the Yamaha are not quite as clear, at least on the baby Advents I'm currently using. Sometime this week I want to check the Nak out on speakers with a bit more bass, but so far, so good.
Thanks again. Maybe two years from now Google will send someone else to this thread, so I'll make sure to give it some nice keywords like Nakamichi TA-3A TA-3 receiver protection circuit power light blinks no sound ... there that should work.
-Jack
Old 26th April 2008, 02:34 AM   #8
Hello Jcro:
I have the same problem with the protection circuit Nakamichi TA-3A, and want to be able where to find R309L and R309R in the amplifier and change them.
Thank you.
Urbina
Old 26th April 2008, 02:34 AM   #9
Wink Nakamichi TA-3A
I need help to locate the resistances R309L and R309R that must change in order that the protection circuit does not fail.
With the manual of service or orientation probably could achieve it.
Thank you
urbinab2
Old 26th April 2008, 06:14 PM   #10
They are on the main (big) pcb ... you need to move the tuner pcb and the control pcb out of the way to see them.
The circuit board should be marked with the resistor names .... look towards the left front of the circuit board for one of the resistors and towards the left rear for the other.
The numbering is fairly consistent, so if you see things like C308L you know that R309L is somewhere close.
If I locate a diagram I will post it.
-Jack
Need suitable transformer for Nakamichi TA4A receiver gto127 Parts 0 23rd January 2009 02:19 AM
Nakamichi Receiver 1 PA 456jss456 Solid State 2 6th February 2007 11:58 PM
Nakamichi receiver RE-10, microprocessor problem? box63 Solid State 0 8th September 2006 03:22 PM
Nakamichi Stasis ?'s-balance issue Heiney9 Solid State 8 2nd June 2005 12:35 PM
Nak Stasis Receiver-Help for service Heiney9 Pass Labs 1 28th April 2005 10:47 AM
Page generated in 0.10032 seconds (88.75% PHP - 11.25% MySQL) with 11 queries
