#11 |
My homebuilt A30 is a little much for it's heat sinks. I intentionally gave it higher than spec'd rails so it gets hot. If there's the slightest bit of breeze it's OK, but where mine lives there isn't much of a breeze, so I modified the power supply to switch in sets of inductors to give it a LC power supply instead of the usual C power supply. In addition to the additional filtering it lowers the rail voltage, thereby lowering power. I don't know if a stock A30 chassis has enough space to add 4 inductors. I made the mistake of getting inductors that run too close to their rated current so I get a little mechanical hum when I have them in circuit, but I can switch them off at will.
Rob |
#12 | |
12volts to 50volts is quite a large ratio. Gajanan Phadte |
#13 |
Can the same power lowering effect be achieved by removing 2 output transistors (Q6/Q9)? How is this different than lowering the current source current by altering R19 and R14?
Also, can the input DC blocking cap(C11) be simply bypassed if you know for certain your source has no DC offset? What R19 and R14 values would give roughly half the power of the normal A30? I guess that would mean 100watts roughly instead of 200 watts idle. Thanks Nelson. |
| class D PA power amps tweaks | NurEinTier | Class D | 1 | 22nd August 2008 05:23 PM |
| How about a round-up of Class A kit power amps, or collectable vintage class A? | Brisso57 | Solid State | 4 | 14th February 2007 10:30 AM |
| Balanced tube preamp for class D power amps. | jane | Tubes / Valves | 5 | 13th December 2006 07:41 AM |
| SMPS design for power amps (Class D in particular) | Bruno Putzeys | Class D | 138 | 17th November 2004 04:24 PM |
| Page generated in 0.06656 seconds (72.47% PHP - 27.53% MySQL) with 10 queries |
