THE RED SQUARE,two figure are printed wrong,
at the begging ,the am worked well, and after a long time ,the am didn't work. and when i put two conponent in correct position,but,the IRFP 240 current get very big,5A, why did this happen? |
#2 |
sch.
#3 |
Aleph-M?
Seems to me that circuit once had another name....oh well, you can't have everything. If you're getting 5A, chances are good that the voltage across the 390 Ohm load to the front end is too high. That would drive the output MOSFET (the one on the bottom) into some pretty serious conduction. You'll need to check the rest of the components. It wouldn't surprise me if one of the front end MOSFETs is roasted. Grey |
#4 |
diyAudio Moderator Emeritus
Hi, Xr000,
You buy the PCB from where? Is Mr. Nelson Pass know about this? He's the owner of all Aleph design. |
#5 |
I get the SCH from web.
and the board were produced myself!. |
#6 |
If you get curious about the history of that design, you might look up a thread here called "The Mini-A"
Grey |
#7 |
ok,he he ,thank you again.
#8 | |
#9 | |
#10 |
Very beautiful!
Support!!!! |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Pass X250.5 right channel hum problem | georgehifi | Pass Labs | 1 | 3rd July 2006 07:06 PM |
| Pass labs x2 gian problem | AH JUI | Pass Labs | 0 | 27th February 2004 03:04 PM |
| adcom gtp 500ll tuner problem, Nelson Pass maybe? | crippledchicken | Pass Labs | 11 | 21st January 2004 11:36 PM |
| My opinion on Pass Labs and Mr. Pass (Nelson) himself | b_online | Pass Labs | 11 | 21st May 2003 12:39 AM |
| Page generated in 0.08843 seconds (79.06% PHP - 20.94% MySQL) with 11 queries |
