I am about to begin building the BOSOZ and I have a few questions about chassis construction.
I will be building my own chassis for the preamp out of wood or a combination of wood and a metal frame. I have read here that an all wood frame is fine. Yes? My question is: What is the advantage to putting the preamps in different boxes than the power supplies. I understand the distortion issues and such. But, if I have the means and ability to build two or three chassises, separating out parts that don't always play together nicely, is this: 1. highly advisable 2. somewhat advisable 3. probably won't make that much difference in the end And, how best should I separate the parts? Thanks for the help. This will be my first build and... as they say "well begun is half done." |
#2 |
The best reason for putting the power supply in another box is to keep the transformer far away from the signal wiring.
Would a woodchuck bother to chuck MDF? |
#3 |
Agreeing with eLarson. If you can afford the additonal hardware and space, I would say it is "1. highly advisable". I like putting half of the 'pi' in the separate basket
#4 |
Thanks for the advice.
#5 |
Where do ya'll who buy them, buy your chassis for your amps and preamps?
#6 |
Master Burner
I got my cases from group buy here. I think some people have been mentioning Par Metal as a good source for the case: http://www.par-metal.com/
There is also Front Panel Express, where you could design and order aluminum panels to be cut and drilled by your design for very reasonable price. Separate case for the PS is good in order to separate transformer from the signal wiring, but if you have enough space you can make metal deviders for the transformer which will do good job as well. Here are my images for two case XBosoz: X-Bosoz Finished |
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| chassis construction | theChris | Chip Amps | 19 | 12th January 2006 02:59 AM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Son of Dork: Chassis and Construction | dorkus | Solid State | 18 | 13th December 2002 01:28 PM |
| Page generated in 0.07597 seconds (78.40% PHP - 21.60% MySQL) with 10 queries |
