Old 26th August 2002, 07:57 PM   #11
The one and only
Nelson Pass's Avatar
We use the CL60, which as I recall goes down to 5 ohms
or so inside the warm amplifier, unless it is the AC
line thermistor, in which case it is more like an ohm.
Old 26th August 2002, 08:38 PM   #12
trigon's Avatar
Hi.
Mr. NP thank you for the replay. Here is additional info.
CL-60
10 Ohm at no load @ 25C
5 Amp - Max Steady State Current
.18 Ohm - Approx Res @ I max
CL-70
16 Ohm at no load @ 25C
4 Amp - Max Steady State Current
.27 Ohm - Approx Res @ I max
So for this particular Thermistor CL-70 which has 16Ohm resistance and 4A current, I guess if I put 2 in parallel that should drop the resistance even more and increase the current for the regular state.????? Unless I am wrong in my calculations.
Thank you kindly in advance.
Trigon.:headscrat
Old 26th August 2002, 09:02 PM   #13
Nicwix is offline Nicwix  Australia
Hi
Does the thermister takes a long time to reach steady state conditions, since its resistance depends on case temperature?
Obvious alternate approach is a resistor on the mains side of the transformer bypassed by relay contacts that cut in after say 10 seconds.
Any comments?
Nix
Old 26th August 2002, 09:04 PM   #14
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Thermistor gets hot in less than 3 seconds. If you use crappy Chinese bridges, like I do, it is not always a perfect protection.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th August 2002, 11:25 PM   #15
The one and only
I use CL60's at 2 to 2.5 amps, and not above, as they
get quite hot. I have seen failures at 4 amps or so, so
above 2 amps I run 1 each on the dual primary windings.
Old 26th August 2002, 11:35 PM   #16
trigon's Avatar
Thank you kindly Mr. NP
Trigon.
Old 21st October 2002, 11:15 AM   #17
kirc is offline kirc  Slovenia
kirc's Avatar
What about using Epcos Inrush Current Limiters ?
Type: B57238S100M000 has 10ohm resistance at 25°C and max current is 5A.
It's usefull for switch-mode power supplies and soft-start motors,..(probably is usefull also for power-up toroid transformer).
Does anyone have some expirience with this thermistors ?
best regards,
Leon
Music is a part of my life, DIY is my life.
Old 21st October 2002, 05:39 PM   #18
Send a message via AIM to xenofex Send a message via Yahoo to xenofex
I'm plan to use only 2 thermistor CL50 one at primary windings.
of X'former and the other one for the safety ground. Is this going
cause any problem coz the total capacitance value for my Aleph5 power supply is 317mF?
Specs for the thermistor CL50
1. 7 ohms at 25 degrees C ( ambient )
2. Max steady current - 5 Amps
cb
Old 21st October 2002, 08:01 PM   #19
The one and only
It will probably work, but be very hot.
Of course the worst it can do is fail.
Damn! Another dollar down the toilet!
inrush current doktor Solid State 123 20th February 2012 02:26 AM
Thermistor or relay for inrush protection Kees Solid State 17 14th April 2005 05:14 AM
inrush current Jules Tubes / Valves 8 26th December 2003 05:38 AM
Aleph 5 inrush current protection vossie Pass Labs 33 6th December 2002 02:36 PM
About Inrush Current JDeV Parts 0 2nd December 2002 06:40 AM
Page generated in 0.08660 seconds (81.72% PHP - 18.28% MySQL) with 10 queries
