My BoSoZ time for improvement
Old 13th April 2006, 05:40 AM   #21
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
I do NOT use safty-earth.
I have tried to make different connection to GND from -IN, also I tried to GND the -OUT, It doe's not make any difference. There is a small humming, in diskant and bass, and a little bit of 'hisssss' in the midrangespeaker.
It's the same 'level' howmatter where the volume is. (high or low)
How are you running it unbalanced (if you do) ?.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 13th April 2006, 05:52 AM   #22
JDeV is offline JDeV  United Kingdom
Yes, I use single ended input. Are you sure these noise come from the BosoZ and not maybe from your power amp?
Old 13th April 2006, 05:55 AM   #23
lykkedk's Avatar
When i connect, from another source to my poweramp, i got no noise.
Could you perhaps, tell me, how you run it unbalanced (excatly) ?
Thank for helping on the way.
Old 13th April 2006, 06:21 AM   #24
lykkedk's Avatar
The difference, between my old BoSoZ and the X-Bsoz. as I see it.
Changes on X-Bsoz:
1 connection, from PSU, is at the other side of the R117/R116.
2 No Resistor after C101/C102 except R112/R111.
3 10uF -> 33uF Cap. (i use 10uF still). could this be problem ?
4 10K resistor in serie with +IN / -IN eg.. +IN from slider -----> 10KOhm --->
Maybe I have to connect, like the normal BoSoZ (made the PCB so it's possible). to see if the little problem is gone.
EDIT also the X-resisters R122/R123 is there.
Old 13th April 2006, 01:32 PM   #25
steenoe is offline steenoe  Denmark
steenoe's Avatar
Jesper, just in case its in the grounding scheme, you can compare your layout to this nice and clear drawing that JH6you made some time ago.
Its pretty good to have as a guideline.
Steen
Old 13th April 2006, 05:12 PM   #26
lykkedk's Avatar
My solution, was to swap back to the old BoSoZ design, as I mentioned earlier.
I used the same ground connection's, just plugged out the 'X' resistor's the 10K series resistor, and placed a resistor 124Ohm(R15). The potmeter i moved to output. Input fixed with 10Kohm to gnd, and a R18, or in short, excatly the old design. R14 shorted to GND at -IN for unbalanced.
Suddently all hum and hiss was gone, as I expected.
I think the sonic is just the same for me, as the 'X'-et one. The better quality I noticed, when playing with x-bsoz, must have been my new steenoe-cap aka' RIFA phe426, cause i never tried with my old VISHAY's, in the 'X'et version.
Sorry about the confusion, but honestly, i am not very ear-trained listning to HIFI. through it get's better all the time!
The gain is slightly better now (~13.5dB) compared to my old BoSoZ (Don't know why) The more gain is something my LeachAmp really like's.
I will let the BoSoZ BURN in for the rest of the Easter, maybe the new part's sounding even better then....
Some of you, may wonder, why I even made a new PCB, for that the answer is, that i am construction a new chassis, something i ofcause will come back to here with one day...
My GOAL was to make improvement's to my BoSoZ. I ended up with a new PCB, for both a x-bsoz and bosoz version. A new ALPS 10K motorpot, 4 new
caps, and some new resistor's.
FINALLY, i would like to tell, that i now am perfectly happy with my BoSoZ.
Thank you all for helping.
Old 14th April 2006, 05:32 AM   #27
jh6you is offline jh6you
Account Disabled
Bosoz perfectly improved yo ears . . .
Old 14th April 2006, 06:36 AM   #28
lykkedk's Avatar
That's for sure ! Something i had to do while listning today.
Mounted some heatsink on resistor's, cause they grow hot
Think the amp is 'Termal' stable now through.
Old 14th April 2006, 09:02 AM   #29
Account Disabled
I was drunk more on Carlsberg than Tuborg . . .
Skaal ! ! !
By the way, the wire arrangement in you web world pictures look Dansk good.
Good reference for my future web site . . .
Old 16th April 2006, 07:54 AM   #30
lykkedk's Avatar
I have updated my site. EDIT click on My new project, BoSoZ with new chassis.
My Diy Site's
My BoSoZ time for improvementHide this!Advertise here!
PPI A600 improvement manina Car Audio 7 3rd April 2009 03:16 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
One more time, P3&P4 / BoSoZ tobias_svensk Pass Labs 3 5th March 2004 08:33 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 12:55 AM
Copyright ©1999-2017 diyAudio
