#551 |
more turns - more stray capacitance yukyuk
keep it at bay - saying that you need entire core covered with wire , so one layer is minimum sort of gamble - will you go to use 1KW5 , 2KW or 3 whatever you choose - I see no reason to cry later ; btw. capacitance can be somewhat lowered with connecting small chokes in series with each winding
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#552 |
So ordering 3 KVAs with only the primarys wound for 2*115 V would be a fair gamble? The audiogrades will be with epoxy filled centers so I can not unwind it.
#553 |
yup - just primaries ;
if you can , say that your goal is rather fully covered core than exact number of turns (needed for any voltage ) they don't care - that's just few clicks on machine control panel
#554 |
Well as far as I know the primarys for 2*115 V usually goes in some layers on toroids so it should cover the core all righty.
#555 |
anybody has recommendations what to use for the 47 uF input caps?
#556 |
nothing wrong with Elna Silmics , bypassed with small MKC
#557 |
So you dont think I should go straight on those stuff?
B32526T1476K EPCOS | Mouser B32678G3476K EPCOS | Mouser FFB44E0476K AVX | Mouser /Staffan |
#558 |
you're wasting your moony , not mine
#559 |
No, I'm mooning your waist
![]() Ok, It was the word waste anyway that I needed. Thanks Staffan |
#560 |
Hi
I'm on some early projecting here and had a lookie in my closets. I had some 400 VA 2*12 VAC that I could use one per monoblock with dual graetz. Then I could do with dual 25 V caps per rail and RC. Or I also had some 400 VA 2*24 VAC that i could use. Then I need single 50 V caps. What would you prefere here? And what values on the filtercaps per RC? Best regards Staffan |
| Using mains transformer as output transformer | Elias | Tubes / Valves | 176 | 11th March 2013 09:35 PM |
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 05:05 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 10:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
