ZV7-T (transformer) - Page 54 - diyAudio
Old 12th June 2008, 01:38 AM   #531
Paper mache horn fabricator
carpenter's Avatar
Thanks for the advice, Choky.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 12th June 2008, 01:43 AM   #532
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
naah ....
you're big boy ( with big horns )
you already knew that
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th June 2008, 03:07 AM   #533
carpenter's Avatar
Still, you're a peach!
Old 13th June 2008, 01:56 AM   #534
carpenter's Avatar
Now, this is fun. I simmed Nelson's ZV3 regulated power supply and attached it to my latest creation. Wonder of wonders, it works!
What blows me away about this process is that the voltage swing is rail to rail--at least the sim thinks it is. Now I can put my transformers to work!
File Type: png zv7-t jfet amp with zv3 regulated ps.png (45.1 KB, 177 views)
Old 15th June 2008, 03:33 AM   #535
carpenter's Avatar
I cleaned up the LU1014D ID/VDS graph. Here's the area of the graph that I find most important. Perhaps someone will find this useful:
Old 15th June 2008, 09:14 PM   #536
carpenter's Avatar
I split the ZV7-T (with cascode) down the middle and added what I think could be called a balanced-in-to-single-ended-out buffer. It also has Nelson's voltage regulator. So, I guess it more resembles a ZV9. Performance looks good on the simulator. The best part? Being single ended, it's easier to build.
My electronic x-over has balanced outputs--hence the desire to employ a balanced to single-ended converter.
Old 15th June 2008, 09:26 PM   #537
Zen Mod's Avatar
why caps everywhere ?
at least C6 , C11 ,C12 , C13
and- that output load choke must be substantial ...... considering massive Iq ( it isn't split load choke , where yo have flux cancellation )
Old 15th June 2008, 09:46 PM   #538
carpenter's Avatar
Thanks for looking. I'll sim without the caps you mentioned. Again, thanks.
The power in the inductor is 16 watts RMS according to the simulator. The tranny I have on hand is rated at 1000 watts. I figured that the core may be large enough to tolerate the inductance without saturating. I haven't learned how to create a full-blown inductor in my simulator, yet.
Your thoughts are much appreciated, Choky.
Old 15th June 2008, 09:48 PM   #539
carpenter's Avatar
Here's an idea I have of turning VR1 on its side and using it to control the amount of negative feedback in the amp:
Old 15th June 2008, 09:52 PM   #540
carpenter's Avatar
I removed those four caps and everything is looking good; in fact, the sine wave looks exactly the same on the simulator. Thanks a bunch for the education.
Using mains transformer as output transformer Elias Tubes / Valves 176 11th March 2013 10:35 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 06:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 11:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 09:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 05:36 AM
Copyright 1999-2017 diyAudio
